simple solution for controlling rear bags?
maybe this should be in "suspension" forum???
Im leaning towards putting bags on the back of my ’67. I don’t wanna hop, skip, or jump with it… just get about 5 to 6” drop in the rear and be able to pressure up for loads… and maybe drop to the frame to load objects (motorcycle, etc) in the bed. I DO want it to be SAFE! I will probably start out with Schrader valves for simplicity and to see if I really like the bags better than springs. (thinking of Firestone 2600’s or equiv.) For future plans I am wondering if anyone has used a system like in the link for running simple air bags as the only support for the rear? Without a tank and lift/dump valves etc. I could always just mount a compressor and a switch and some air hose to fill the schraders but having control in the cab seems much nicer! Thanks! ![]() ![]() |
Re: simple solution for controlling rear bags?
I just bought a 72 where the guy did just that.. Firestone bags and a Schrader valve.. unfortunately something failed on the way home with it.. but if done correctly, what you suggest sounds fine. He put a valve solenoid on it to drop it, wired to a simple rocker switch. But, in his set up (now mine, but going away soon), you have to hit the switch, then manually press the schrader to deflate.. I guess he planned on switches at some point. In your case you can avoid the valve solenoid thing, and just use the schrader. We had a 77 F150 with simple air shocks and a schrader, worked for many years to haul an in bed camper.
I will say, while I was driving the 72, it drove like a new car on those bags. Last edited by Street Lethal '72; 09-03-2010 at 11:34 AM. |
thanks.
at first i'll run schraders and probably carry a battery (or lighter) operated air source... I roll redneck! wonderif if someone has run something like the links above too? |
Redefining LowBudget
just to give you an Idea becasue when I asked I could never get the answer I run about
35/40 lbs in rear I have no compressor but a 3 gal air tank will lift the REAR a couple times and the front once ( keep in mind its lifting a 500 caddy) on the cheap ( you roll redneck I'm border Gheto) yes you can just run just schraders...also when you goto wire up solinoids use flat 4 trailer wire....you need 2 wire for each corner ( up and down) so the flat 4 makes wireing them up the the front a breeze.....gheto or just smart?? you decide
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
C/10 CLUB MEMBER
![]() Join Date: Jul 2003
Im running this kit from ECE...works great.
-Ron- ![]() |
thanks guys.... very much obliged!
Hey OldSkool71, do you have a number on that system or what its called?
Thanks!
'67 C-10 Shorty - 454, 5spd, and speed holes! |
Gearhead
I have had that ECE rear kit (minus compressor system) for probably 5-6 years now and never had a single problem. I just have schrader valves (were mounted in the rear, now I have them in the cab) and use an Airlift compressor with a 1 gal tank. I ran the tank line into the cab and have all four air bag lines and the fill line in a center console. I can dump/fill the bags' from inside the truck and have a switch on the pressure switch to turn off the compressor if needed. (And you thought you were redneck!!)
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#10 | |
what bags are on that ECE kit?
Gearhead
Ok there are plenty of detailed pics of the my entire set-up in my build thread, but heres a pic of the current center "console" set-up I have.
The ECE bags are Firestone, plenty heavy for all the payload I have ever had. ![]() ![]()
