Old 09-03-2010, 11:00 AM   #1
CHONGO
CHONGO's Avatar
headers for small block on L6 mounts
What headers will fit for a small block on L6 mounts with a manual trans?
1927 Dodge brothers 3 window Rat Rod
1968 GMC ol skool shop truck (LIL MANS PROJECT)
1980 Z/28 (lil mans race car to be)
1964 SWB panel truck
2000 S10 ls x cab Aluminum headed 355
2006 Harley Davidson Night train
CHONGO is offline   Reply With Quote
Old 09-03-2010, 11:18 AM   #2
Overdrive
Sawzall User
Overdrive's Avatar
Location: The snow infested Prairies of Canada (aka: Winnipeg, Manitoba)
Re: headers for small block on L6 mounts
Block hugger headers would fit for sure.
'67 GMC 910
Overdrive is offline   Reply With Quote
Old 09-06-2010, 10:49 AM   #3
CHONGO
CHONGO's Avatar
Thnx for the reply, anyone else or any pics on different headers used in this swap?
Old 09-06-2010, 01:23 PM   #4
guyryan100
guyryan100's Avatar
See this thread http://www.67-72chevytrucks.com/vboa...d.php?t=173037 for my setup. Summit brand headers fit fine. Concensus seems to be that these are re-labeled Dynomax headers.
guyryan100 is offline   Reply With Quote
Old 09-06-2010, 01:25 PM   #5
guyryan100
guyryan100's Avatar
Wait I read your quesion backwards. My engine is in the forward position. Pics show how much clearance I have.
Old 09-06-2010, 06:05 PM   #6
pitbull784
I used a set of hedmans for a 67-87 on mine and they cleared the linkage just fine. I am also running small block w manual trans on the l6 mounts
pitbull784 is offline   Reply With Quote
Old 09-12-2010, 03:30 AM   #7
CHONGO
CHONGO's Avatar
Thnx for the replys.
Old 09-12-2010, 06:55 AM   #8
slowtruck
I've got I6 mounts on a sbc and used headers for a second gen Camaro. I used them because my truck is lowered and the collectors don't drop below the frame.
PM me if you would like to see pics of the setup.
slowtruck is offline   Reply With Quote
Old 09-12-2010, 07:29 AM   #9
kq4pc
Hey Slowtruck, I would like to see pictures of your headers setup.i have been looking for some new headers. thanks Bobby
36 master 36 master delux coupe,6cly,3sp. 58 impala,348 3 duces,4 sp. 56 belair,302,4sp,12 bolt. 2000 silverado,5.3 auto. 65 foo foo rd,352 auto,for sale
kq4pc is offline   Reply With Quote
Old 09-15-2010, 08:39 PM   #10
slowtruck
This is a set of pacesetter headers for a 70-81 Camaro with the I6 motor mounts, sorry for the delay in getting the pics. Also to let you know the truck is on 2.5" spindles with 2" springs in the front and 5" spring and 1.5" blocks in the rear for a 4.5/6.5 drop. I knoe in the pics it doesn't look like it, but they are 2.5" higher than the Hooker header that are made for the truck.
Old 09-15-2010, 09:28 PM   #11
Mike C
Mike C's Avatar
It looks like 67-72 4x4 headers would work and get you some ground clearance to boot. 63-82 Corvette headers might work as well just eyeballin' 'em.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
