Top 10 Must Have Tools
Howdy from Texas! I cant thank everyone enough for sharing their knowledge here. It has helped me, being the greenhorn that I am, tremendously. Being new to bodywork and mechanics, I need to outfit my workshop with some new gear. I used the search function and didn't find anything like this so here goes. Being new to all aspects of restoration, what do you consider the top 10 most important tools one needs to have on hand to start the process effectively. Once again thanks to everyone in advance.
Hanky the newb |
![]() Join Date: Nov 2009
Re: Top 10 Must Have Tools
For my shop:
1. Air Compressor 2. Bench Vise 3. Drill Press 4. Welding Machine 5. Cutting Torch 6. Floor Jack w/ good stands 7. Engine hoist 8. Good selection of Sockets, Wrenches, etc. 9. Square, Level, Tape Measure 10. 4-1/2" Grinder Just my 2 cents worth but without these tools i could not get anything done as i am sure you would agree. Don't forget to ALWAYS have a Fire Extinguisher within an arms reach too. Last edited by CVA59; 09-03-2010 at 03:20 PM. |
and a few others
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and flings your soda across the room, splattering it against that freshly-stained heirloom piece you were drying. WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned guitar callouses from fingers in about the time it takes you to say, 'Yeouw....' ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age, or for perforating something behind and beyond the original intended target object. SKIL SAW: A portable cutting tool used to make studs too short. PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters. BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs. Caution: Avoid using for manicures. HACKSAW: One of a family of cutting tools built for frustration enhancement. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand. WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction of intense welding heat to the palm of your hand. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of. WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 45 minutes. TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity. HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper. EIGHT-FOOT LONG YELLOW PINE 4X4: Used for levering an automobile upward off of a trapped hydraulic jack handle. TWEEZERS: A tool for removing wood splinters and wire wheel wires. E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps neatly off in bolt holes thereby ending any possible future use. RADIAL ARM SAW: A large stationary power saw primarily used by most shops to scare neophytes into choosing another line of work. TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect. CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle. AVIATION METAL SNIPS: See hacksaw. TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, 'the sunshine vitamin,' which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40- watt light bulbs at about the same rate that 105mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading. The accessory socket within the base, has been permanently rendered useless, unless requiring a source of 117vac power to shock the mechanic senseless. PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids, opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads. STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws. AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact gun that grips rusty bolts which were last over tightened 40 years ago by someone at VW, and instantly rounds off their heads. Also used to quickly snap off lug nuts. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. HOSE CUTTER: A tool used to make hoses too short. HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent to the object we are trying to hit. MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use. It is also useful for removing large chunks of human flesh from the user's hands. DAMMIT TOOL: (I have lot's of these) Any handy tool that you grab and throw across the garage while yelling 'DAMMIT' at the top of your lungs. It is also, most often, the next tool that you will need after a really big hammer Sorry, I just couldn't resist
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
![]() Join Date: Nov 2007
I would add:
My very best piece of equipment is a heavy steel work bench (1/2" steel plate top). Weighs several hundred pounds. Bolt the bench vise to that, and get a good large one, Columbian brand if they still make them. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
![]() Join Date: Oct 2009
My favorite tool on the planet = that silly little three-pronged ignition switch bezel removal tool that i never can find when i need it and end up whackin it with two screwdrivers in opposite directions, which works, but if not done perfectly results in a screwdriver inadvertently through the instrument lens....
Yeah, that's my favorite tool. And a hammer. Maybe I'll bunjee cord it to my drill press chuck key so I don't lose it! I NEVER lose that. Either. |
I can see that I am in for a long ride. Damn, a newb is in way too deep. Please carry on........
![]() Join Date: Sep 2006
Duct Tape....
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
1. Pressure Washer
2. Floor jack 3. 6" cut off wheel 4. Impact wrench 5. Saws all 6. Socket set 7. Screw Driver set 8. Mig welder 9. DA sander 10. SAFETY GLOVES AND GLASSES !!!!!
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#9 | ||
Redneck Hillbilly
![]() ![]() ![]() ![]() PAPER TOWELL: A paper cloth very useful for turning a neatly contained pool of spilled liquid into random drops all over your shop floor between said pool and the trash can you can't seem to find. ![]() |
#10 | |
Real Greasers use "Murray's"
![]() ![]() ![]() ![]() ![]() Thanks for the laugh, great post ![]() Quote:
When you,ve got what you think you need from above or have access to, the best tools and most important are common sense and patience.
Hey Watch this...
![]() Join Date: Sep 2007
You can pretty much disassemble your truck with a 9/16" box end. What else would you need?
What have I gotten myself into now? 1964 Chevy Stepside - 383 hydraulic roller Vortec ... a work in progress 2000 Volvo V70R - 340awhp, 22psi, meth-injected of Porsche-eating fun. The grocery-getter on steroids |
#13 |
All below are for removing the old rusty bolts etc....
Brass Hammer Benzo torch PB Blaster Sawzall Safety Equip (glasses/earplugs/Respirator gloves etc.) Both me and OL Skool can vouch for the Safety stuff. I ground the tip of my finger and Ol Skool tried to remove his finger. Thats a pic he should post for ya. LOL
Cheers David 66 LWB Fleet (on hold) 64 LWB Fleet (daily driver) 65 SWB Fleet (almost finished as a driver) 64 SWB Fleet (just started - "Tommys Hot Rods" tribute truck) Nothing worth doing, is easy. |
#14 |
In all seriousness........Harbor freight will be your friend for the following items:
Sanding disks Paint removal wheels (looks like a coral disk $5 at harbor, $16 everywhere else) Clamps Both magnetic and locking Spot weld drill ($4 bucks at HF) A cheap welder if u really don't have the money to buy a decent one Sawzall ($20 at HF. Mine did everything i needed and is still going strong) 4" angle grinders ($20 at HF and theyre disposable LOL) Electric Impact gun ($50 at HF and mine is a champ) Impact socket set If ur gonna stick with Drums get a Brake tool kit Bench Vice Wire Wheels are cheap at HF Jack stands (bought mine at Bi-Mart and they are good ones) Screwdriver set Ratcheting wrenches (bought at Costco $20) A good set of Drill bits Electric Drill / Batt Drill A good Head lamp Compressor and associated tools (blower/Cut off tool/paint guns etc. ) I just built up the stuff I have over a while. I figured I could allow myself a tool per paycheck and I did it that way. Some times I just had to get em coz I really needed em to complete a task. Go on line and print urself off the %20 off coupons for Harbor and that will help.
#15 |
I love the Harbor Frieght 6 inch disk Grinder but we have been using cut off wheels with No gaurd....NOT SMART. My good luck turned bad one day and ran the cut off wheel through my finger all the way to the Bone. I was a combat medic so I threw in a few stitches there in the Gargage....so add Stitching Kit to the List of TOP TOOLS...
#16 | |
Desert Dweller
![]() I could have used your skills a few times ![]() Tony Posted via Mobile Device |
#17 | |
#18 | |
#16876
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#19 |
SIR
#1...EDUCATION!!! you can sharpen your skills by attending your local community college and take a welding course,and PRACTICE..PRACTICE...PRACTICE..that's some of the best money you will ever spend...
66long low fleet http://community.webshots.com/user/LVNR66 |
#20 |
fridge full of beer!!!!!!!!!
'79' shortbed |
#21 |
![]() Join Date: Aug 2005
Tap and die sets go a long way when dealing with rusty old hardware.
#22 |
I agree......its not in my top ten tools but your right A good tap set is a big help
#23 |
Ya need me to come over and do some Stitches glendale . hahahahahaha....mine was maybe deeper but yours is impressive...
nice to know someone other then me is that stupid..welcome to the Club
#24 |
left handed....hahahaha
#25 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I need to get me the correct tool for the knob bezel nut removal.
Also a Steering wheel pulling tool. Also a miner's headlamp.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
