Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-03-2010, 06:18 PM   #1
kwhite4
Junior Member
kwhite4's Avatar
Valve Springs
How often do you guys have to change your valve springs?
I have Manley springs on mine amd she runs fine but with an 800 lift roller cam there has to be some serious spring pressure there.
Guess I need to break down and check them, so far two years and I haven't had to make many adjustments on the valve train.
Anyway I know the springs can be an issue and was curious what kind of time you guys were getting with yours.
Keith
68 GMC
565 BBC
Abruzzi super pro glide
9.85@135.00
kwhite4 is offline   Reply With Quote
Old 09-03-2010, 07:45 PM   #2
Super73
Super73's Avatar
Re: Valve Springs
I had about 15k on my Crane 832's. But it was a little .610/.612 lift hyd cam..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-04-2010, 07:47 AM   #3
regan wilson
regan wilson's Avatar
Re: Valve Springs
I have over 900 lift with a 2.200 spring and Titanium valves. I change them at or before 150 runs along with rings and lifters . On your deal you can probably go alot further maybe even 300 but at that point you really need to stay on top of the pressure. I would say 200 runs to be safe . You dont need to float the valves .
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
Old 09-04-2010, 09:53 PM   #4
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Valve Springs
Regan.....love your intake! Who stitched 'er up??
prostreetC-10 is offline   Reply With Quote
Old 09-11-2010, 12:25 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Valve Springs
Manley 650 lb. per " NexTex springs, 320# on the seat 830# on the nose. Beat up on them a little bit like Regan does,, there good for a season (about 50 miles if it's a good season )
One of your best friends here is LSM. The actual # you read is really not the issue. CHANGES in the # is important. When springs go away they start beating things up REAL quick. With titanium valves running about $120 EACH it's not something you let go unchecked. Figure $1800 in valves and $600 for lifters,, letting spring pressure go unchecked can get REAL expensive in a big hurry. This little LSM gadget will give you a reliable # to compare to your baseline in less time than it takes to adjust the lash.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
