09-04-2010, 11:40 AM | #1 |
rebuilding front suspension... advise?
Howdy all,
I bought a set of upper and lower control arms at the local jy to begin a rebuild project on the 81. I'm gonna build the arms first and then swap them to save some time.. Basically a stock style recon with new bjoints, bushings, tierods and idler,etc.. to tighten things up. the truck is static dropped on 3 inch spindles and 2 inch springs. *** 2 questions for any takers: 1. I can price moog bushings, balljoints, and stuff at any of the parts houses, but wondered if the "Energy suspension" red bushings are worth the extra cost? (I am not an aggressive driver, so the handling part is not AS important to me) I have heard that they are a little noisy. 2. To get the camber correct there is a mess of shims on the upper arm. I have had 2 instances where the shims come out and I have to take it back to the front end shop. Any fixes for this while the arm is off? I thought about making a couple of thick shims out of bar stock. (like 2 1/4 inch shims) that bridge from one upper control arm bolt to the other that can be put on prior to installing the arm. (with holes instead of slots) |
09-04-2010, 12:17 PM | #2 |
Happy to be here
Re: rebuilding front suspension... advise?
If it were me, I would go with the Moog parts for direct replacements, OR upgrade to poly-graphite bushing offered by some of the aftermarket suppliers. I do not care for pure urethane bushing because they are prone to squeak even if you use the supplied lube.
www.p-s-t.com www.performancesuspension.com
09-04-2010, 04:27 PM | #3 |
Use quality stock parts, like moog or spicer, they'll last a long time and will give you a quality ride. Cheap out and you'll be back here complaining about a rough ride and lose steering even with new parts.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
09-05-2010, 11:13 AM | #4 |
I just rebuilt/replaced everything under the frontend of my '76 Blazer. I used all Moog, and am very pleased with how much better it rides and steers. Be aware, changing those bushings in the lower control arms are a PITA. Just take your time and it'll work out though .
