Old 09-04-2010, 01:04 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Tranny cooler question.
Should I mount this cooler to the inside or outside of the frame rail like streetrodders do or should I find another place. Its made from aluminum so id guess it would dissapate heat pretty good all on its own..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-04-2010, 01:19 PM   #2
big_al_71
big_al_71's Avatar
Re: Tranny cooler question.
Here is a pict of where we mounted mine...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-04-2010, 01:34 PM   #3
cdowns
cdowns's Avatar
the better the airflow the more efficently it works
Old 09-04-2010, 07:41 PM   #4
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Mount it to the inside frame rail on the outside it will be hit by debris from the tires and your tranny lines run on the inside of the frame rails as well
Just an FYI - if you intention is for that cooler to be used in a HD towing or high stall apllication you may want to rethink your options - a plate and frame cooler will do a much better job
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 09-04-2010, 07:54 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
Nope no towin in mind truck will be street driven and only haul itself around.
MEMBER #6377
Project "7DEUCE"
Old 09-04-2010, 10:16 PM   #6
fastom
That's right, it's Copper!!
fastom's Avatar
I mounted mine up front under the truck.
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Gen-II Compact Vintage Air System
PPG paint, Mandarin Copper and Vanilla Shake.
http://www.hubgarage.com/mygarage/fastom
Stupid should hurt and eventually become fatal!
fastom is offline   Reply With Quote
Old 09-05-2010, 02:55 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Are you running the cooler in addition to the stock heat exchanger in the radiator, or just the cooler itself?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 09-05-2010, 09:52 AM   #8
Hart_Rod
Hart_Rod's Avatar
Originally Posted by leddzepp View Post
Are you running the cooler in addition to the stock heat exchanger on the radiator, or just the cooler itself?
I'm curious also. Does anyone have a part number for any of those coolers?
Hart_Rod is offline   Reply With Quote
Old 09-05-2010, 10:26 AM   #9
FRENCHBLUE72
PROJECT 7DEUCE
Rob I dont have a part number as I bought 2 of them at hout august nights from a vendor there.. I do have one mounted on my v-8 powdered yota and it seems to always be pretty cool to the touch but its mounted right out front near the radiator. I was wanting to hide this one under my 72 on the inside frame rail just pass the cab.
MEMBER #6377
Project "7DEUCE"
Old 09-05-2010, 12:35 PM   #10
DPowers
DPowers's Avatar
I bought mine at a swap meet last year- $30. But I think that Summit and Jeg's both carry them. I am using mine as an addition on my '66 and mounted it behind the bumper as well.
DPowers is offline   Reply With Quote
