Old 09-04-2010, 01:50 PM   #1
Big Fenders
Sub Rear Bumper
Need a bumper for my 1960 GMC Suburban [rear]. I know that none are made specificaly for the sub but what are you guys using? I'm thinking that a Fleetside bumper might work but I thought I'd throw it out here first. Will the Fleetside width be the same as the sub? Fabbing brackets not a problem.
Bob
Big Fenders is offline   Reply With Quote
Old 09-04-2010, 02:02 PM   #2
Frizzle Fry
Frizzle Fry's Avatar
Re: Sub Rear Bumper
Isn't the sub rear bumper the same stamp as the front bumpers with different holes?
Frizzle Fry is offline   Reply With Quote
Old 09-04-2010, 06:15 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Sub Rear Bumper
yep
Old 09-05-2010, 12:56 AM   #4
Captainfab
60-66 Nut
Re: Sub Rear Bumper
Yes the Suburban rear bumpers are basically the same as the front bumpers. The difference is in the location of the mounting holes since the rear of the frame is wider than the front. On the '63-'66 2wd Suburbans the rear bumper has a mounting bolt dimension of 32" center to center, and the front is 26 1/4" center to center. The '60-'62 2wd Suburban frames are wider just as the pickups are, but I don't have those dimensions handy. I believe the '60-'62 Suburbans use a bolt on bracket to mount the rear bumper. I may be able to get a pic of that bracket tomorrow.
Old 09-05-2010, 01:06 AM   #5
Brad54
Brad54's Avatar
Re: Sub Rear Bumper
The fleetside bumper has the notch for the license plate, which the Suburbans and panels don't have.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 09-05-2010, 02:53 AM   #6
padresag
Re: Sub Rear Bumper
pu bumper will not work properly due to the dip as the sheet metal on the rear of a sub or panel is higher than the dip and the sheet metal has a rubber seal along that edge
ron
padresag is offline   Reply With Quote
Old 09-05-2010, 08:01 AM   #7
jonzcustomshop
1961 crewcab
Re: Sub Rear Bumper
here are some decent shots of rear sub bumps...
first three are 60-62, notice how far outboard the bolt holes are.
last one is a 63-66 notice the bolt holes are farther in.
sub rears and front bumpers have a little crown to them, wheras a fleet rear is basically flat.
you could probably get away with hanging a front on there until you find the correct sub/panel rear.
would just either have to drill some holes or fab up some custom brackets..
Old 09-06-2010, 12:37 AM   #8
Captainfab
60-66 Nut
Re: Sub Rear Bumper
Here are a couple of pics of the mounting brackets on a rear bumper for a '60-'62 Suburban/Panel. I got sidetracked and didn't get a measurement on the bolt spacing. I'll try and get those dimensions tomorrow.
Old 09-06-2010, 02:46 PM   #9
Big Fenders
Re: Sub Rear Bumper
I think I'll try to hang a front bumper with fabbed brackets and see how that looks. I'm aware of the step in the Fleetside bumpers and can'i decide whether that would stop me from buying one..Thanks all for the help and pics especially helpful..
Bob
Old 09-07-2010, 12:49 AM   #10
Captainfab
60-66 Nut
Re: Sub Rear Bumper
OK. the bolt spacing on the '60-'62 Suburban/Panel rear bumpers is 44 1/2" center to center.
Post some pics when you get something fabbed up Big Fenders.
Old 11-05-2010, 08:46 PM   #11
SRVBLUES64
Re: Sub Rear Bumper
im looking for front and rear bumpers for a 66 chevy truck, paintable
SRVBLUES64 is offline   Reply With Quote
Old 11-14-2010, 11:51 PM   #12
KIC
1960 GMC Burb
KIC's Avatar
Re: Sub Rear Bumper
You can always look at my 60 to measure/match what you need.
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
Old 11-15-2010, 12:54 PM   #13
jbgroby
jbgroby's Avatar
Re: Sub Rear Bumper
Uh....Let get back to the Purple Sub for a moment. There seems to be some sort of blockage of sorts to see the entire bumoer. Good Blockage though
jbgroby is offline   Reply With Quote
Old 11-15-2010, 12:57 PM   #14
KIC
1960 GMC Burb
KIC's Avatar
Re: Sub Rear Bumper
What purple Burb? There is a red, gold and gray one... Wish I could see the purple one...
1960 GMC Suburban
1/2 ton V-6
2003 Tahoe LT
Old 11-15-2010, 01:16 PM   #15
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Sub Rear Bumper
I personally liked the denim bumper, although it isnt easy to see, it sure looked good tho.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
