02-24-2003, 04:43 PM | #1 |
vin tag info?
my vin tag says the vehicle has a gross weight of 4700lbs as manufactured. above it says this includes driver and passengers etc. any idea how much theyre factoring is for everything extra? my truck is a 72 shortbed fleetside. was a 6cyl/3spd/ non a/c now a 350/350
i highly doubt my shortbed can be that much over 4,000 lbs im just wondering how they got this 4700lb figure. also where is the vin stamped on the frame? i want to check to see if it matches my cab. |
02-24-2003, 06:13 PM | #2 |
Fabricate till you "puke"
The gross weight is with payload. My Longhorn states GVW 7500 lbs........but curb weight was around 4800. My guess (and thats what it is a guess!) your short bed probably weighed around 3500 curb weight(empty)... You should find a partial vin on top of the frame rail , in the steering box area......crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-24-2003, 07:17 PM | #3 |
Where's my beer?
This is a pic previously posted by Longhornmail.
And yes, that dirty hand belongs to him That's where the vin on the frame should be.
Paul How do you make the invisible, visible?.........You take it away. |
02-24-2003, 07:22 PM | #4 |
Andy, you better scrub them grubby fingers up dude! The other longhorn(the crazy one)
02-24-2003, 07:37 PM | #5 |
Cantankerous Geezer
In the early 70's the camper craze had hit. Camper manufacturers were putting campers on their 1/2 ton pickups that were within the weight rating, but they were overloading the rear axle, making the pickups hard to control. So, the government changed the way load ratings were calculated. With this, a 1/2 ton pickup no longer was rated to carry 1,000 lbs. My 74 was rated to carry a load of around 700 lbs which included the driver.
Fred There is no such thing as too much cam...just not enough engine. |
02-24-2003, 07:52 PM | #6 |
Take it to a local scale and get it wieghed for about $8. "CAT" is a nationally recognized and certified scale operator. Should be one near you somewhere...
My '72 weighs in at 4800lb, no payload, full tank of gas. The 3/4 ton chassis adds alot as does the BB that has my front end almost dragging... Truck originally had a 350 and the published weight according to WA DMV was 4238.
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454 '93 K2500 Suburban, Old 454 (157K) |
