09-04-2010, 07:17 PM | #1 |
3/4 to 1/2 ?
Can you put 1/2 ton 5 lug parts on a 3/4 ton truck? I know the rear would swap, but how about the spindles out? Thanks.
09-04-2010, 07:19 PM | #2 |
Re: 3/4 to 1/2 ?
What year etc.?
09-04-2010, 10:47 PM | #3 |
Re: 3/4 to 1/2 ?
1975 and 1984.
09-05-2010, 09:53 PM | #4 |
Re: 3/4 to 1/2 ?
i am doing the exact opposite thing and yes they will. Not sure on the ball joints, i am swapping the a-arms with the spindles and they bolt up. Also to make it simpler I am going to pull the pitman arm off with the steering linkage complete so I won't tear up the boots. Pretty much take whole assemblies and swap them and you won't have a problem, haven't checked out the brake booster, master cylinder or the proportioning valve yet but I know the 1/2 and 3/4 parts will swap bolt in wise. Not sure but I think that the brake parts need to be the same as the suspension. If you have both to swap no problems......
steve |
