Replacing leaky valve cover gaskets on my 85 K20
Any suggestions for type of valve cover gasket to use or advice on whether any special prep to the gasket or cover is needed? Thanks for any suggestions. btw- I was suprised how many vacumn lines, left over smog hoses,etc. needed to be moved to pull the cover...just took my time and kept telling myself how much $$ I'm saving by doing it myself.
_______________________________________________ 1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger" 1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel |
The One And Only !!!
Re: Replacing leaky valve cover gaskets on my 85 K20
Fel-Pro gaskets with a light film of
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
Thanks very much....Appreciate the info.
clean the head and valve cover real good, use fell-pro gaskets and glue the gaskets to the valve cover only with 3m weatherstip adhesive. do not over-tighten.
Use Fel-pro or Mr. Gasket and clean the rocker cover and head good. make sure to either get a shop manual or the torque settings from the parts house that you get the gasket from.
One thing you may run into is to get rubber or cork. I usually choose cork as in my experiance it seals better than the rubber. Also, cork has better thermal expansion than rubber does.
79 K20,400 SBC, TBI, 4 speed w/ super low, 4.88's. 89 K2500. 350 TBI, mild cam, longtube hooker headers, glasspack true duals, TH700R4 with shift kit, Corp. 14 10.25'' full float, with 4.11:1 gears, standard ifs cranked to 2 inch lift. RS5000 shocks. ![]() ![]() 96 f350, Powerstroke, ZF6, DRW, 4x4. .Real trucks have 3 peddles. Real drivers float gears!! |
GM Addicted
i am running these ones here. As it says no need for silicon just make the head and the valve cover base clean so there is no debris and they work great not one leak yet. I tend to lean towards "You Get What You Pay For"
Valve Cover Gaskets
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
Thanks all....Felpro rocks...so nice to open hood and not smell oil burning on manifolds/see smoke. Now if I can just solve my small oil leak somewhere on the rear side of the engine (passenger side).
#8 | |
2006 Silverado Crew Cab 1500 4x4 5.3L automatic 1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208 1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his. 1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out. 2016 Nissan Altima grocery getter/commuter |
