Old 09-04-2010, 08:47 PM   #1
Mt Man Chad
Mt Man Chad's Avatar
WTB - Small block V8 PS crank pulley
As it says,
Looking for the front single groove crank pulley for a stock power steering setup on a 1968 327 small block C10.
If you have one please let me know.
Thanks!
Chad
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 09-05-2010, 08:08 PM   #2
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Re: WTB - Small block V8 PS crank pulley
That "stamped" PS pulley is from about 70-72. The earlier 67-69 (?) used a heavy two groove "cast" pulley. There were several PS pump pulleys and brackets, so sometimes they don't all line up when you mix them up. You just have to try them and if they don't work start switching pieces.
If you can get the whole PS system from one truck, you guarantee the parts are matched. I have both the cast and the stamped PS pulleys for $30 each.
PICKMUP is offline   Reply With Quote
