Old 09-05-2010, 04:33 PM   #1
JoeKan
JoeKan's Avatar
Replacing Shocks Question
How can you tell if your shocks need replacing or not? I have the inner fenders off my 72 burb and before I put them back on, wanted to replace the shocks if they need it.
Can someone tell me when is the time to replace them?
Thanks for the help,
Joe
JoeKan is offline   Reply With Quote
Old 09-05-2010, 10:32 PM   #2
texastrendz
Re: Replacing Shocks Question
ill give it a go. how do the shocks look, do they fill like they have any damping when you compress them, are they original, rubber inserts blown out, bent, broke, worn out, these are all factors to look at. my answer is yes since is such a cheap part.
texastrendz is offline   Reply With Quote
Old 09-06-2010, 12:44 PM   #3
blime81
Laid Lo
blime81's Avatar
I was always told if you push down with all your weight and release the truck and it bounces up and down more then twice it's time for shocks.
But if you don't know the age on the ones you have and they don't look new, I'd just swap them. One less thing to worry about. Also if you spend the extra for a better shock you won't be disapointed.
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 09-06-2010, 08:58 PM   #4
JoeKan
JoeKan's Avatar
Thanks for the help. Any suggestions on shocks that won't break the bank??
Old 09-06-2010, 10:38 PM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
hahai replaced mine awhile back...just got cheapos' from parts store
the ones that came off were sprayed black with undercoating by po, when i got em off you pushed em together, and they stayed there lol....
they were ready to come off!
John
1999 Toyota Tacoma 4x4
Old 09-07-2010, 12:20 PM   #6
blime81
Laid Lo
blime81's Avatar
I've had good luck with KYB and Monroe. They aren't the cheapest but I can't complain. Currently running CPPs shocks up front. Not sure who actually makes them but they seem good and were pretty cheap. Haven't had a lot of miles on them yet though. KYBs on the back.
Semper Fi,
Jeff
