Old 09-05-2010, 09:15 PM   #1
JHill
rearend length
can anyone tell me if the six lug rearend are different length than 5 lug thanks
JHill is offline   Reply With Quote
Old 09-05-2010, 09:46 PM   #2
Sammy
Re: rearend length
Width I heard is different. I believe 5 lug axles are longer to match up with the wider disc front crossmembers.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-05-2010, 09:57 PM   #3
Re: rearend length
Some six lugs are the same length/width. The change happened in the 70 year. most prior to mid 1970 were 1.5" narrower that the 5 lug and later model 70 6 lugs. I am told the difference ws to make the front and rear tracks the same when the disc-brakes became an option/standard.
Old 09-05-2010, 10:05 PM   #4
ERASER5
ERASER5's Avatar
Re: rearend length
I type slow. Agree with Palf.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-05-2010, 10:35 PM   #5
Hart_Rod
Hart_Rod's Avatar
Re: rearend length
67-70(early) 62" wide mounting surface to mounting surface
70(late)-72 63.5" wide mounting surface to mounting surface
Hart_Rod is offline   Reply With Quote
