Old 09-05-2010, 09:17 PM   #1
FL71C10
putting 68 396 into 71 c10
Will a 396 automatic out of a 68 3/4 ton truck work in my 71 c10? Could I just use the mounting hardware out of the 68? Didn't know if there were frame differences with the donor truck being a 3/4 ton and a 68.
Thanks!
71 Chevy C10 Shortbed Stepside. LT1 with
4l60E. Just got back from painter, in assembly now.
FL71C10 is offline   Reply With Quote
Old 09-05-2010, 10:10 PM   #2
71swb4x4
71swb4x4's Avatar
Re: putting 68 396 into 71 c10
It will bolt up for the most part. Make sure you grab the frame towers for the engine mounts, those are big block specific.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-05-2010, 10:11 PM   #3
FL71C10
So if I have the donor truck, I should have everything I need? Will this motor run on regular or will it need premium?
Old 09-05-2010, 10:17 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
Is the engine stock, if it is regular will be ok depending on how far the timing is advanced.
I have '73 454 and it runs ok on regular gasoline.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-05-2010, 10:19 PM   #5
FL71C10
I'm pretty sure it's stock. Still has qjet and cast iron manifolds.
Old 09-05-2010, 10:25 PM   #6
El Jay
Gone to greener pastures
X 2
If everything is still on the donor, you should be good to go.
My 402 runs just fine on 87 octane.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 09-05-2010, 10:34 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
I would put a can of SeaFoam in the gas tank with the next fill-up. I usually do that when an engine has not been ran for a while. Most auto parts stores carry it.
