09-05-2010, 09:46 PM | #1 |
67 chevy trailing arm suspension
Hey guys, just picked up this rear suspension for my 56 chevy pickup. what Im wondering is, what is the weakest part of the suspension? Im going to run either air bags or coilovers. Havent made a final decision yet there. Kinda curious if the arms need to be boxed or if the front crossmember needs to be buffed up? Also Im using a 12 bolt rearend out of a newer chevy truck. What are you guys using for a panhard bar since it doesnt have the mount on the rearend? thanks in advance Robert
09-06-2010, 08:50 AM | #2 |
Re: 67 chevy trailing arm suspension
THE PANHARD BARS ON 62-64 CHEVY TRUCKS WITH COILS HAVE BRACKETS THAT ARE WELDED DIRECTLY TO THE AXEL TUBE. LOOK AT THESE & I THINK YOU'LL LIKE THIS SETUP. I'M PUTTING ONE ON A 72 SHORTY THAT I'M PUTTING A FORD 9" IN THATS OUT OF A 75 LINCOLN. THAT WAY I'LL HAVE 4-WHEEL DISC'S. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-06-2010, 09:21 AM | #3 |
The design of the 1967 Chevrolet trailing arm suspension is the same suspension design that is used in all NASCAR racecars today.
The links are the strongest part and do not need to be stiffened up. I had as much as 3 tons of weight inside of my panel truck - and believe me - it would take a lot more then that to bend one of those links. |
09-06-2010, 10:46 AM | #4 |
Moderator
Nothing wrong with the stock configuration at all, remember the load is mostly transferred directly through the springs/bags vertically to the frame. There is very little moment transferred to the arms or crossmember.
I put trailing arms in m '50 and I'm using this panhard: http://www.*****************/4-link-k...r-unwelded-kit
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
09-06-2010, 12:16 PM | #5 |
So Leevon do you have any pics of the panhard bar installed yet? Also no one said anything about the front crossmember being weak?
09-06-2010, 02:35 PM | #6 |
Old Skool Club
Early Classic Enterprises has trailing arms, coil springs, adjustable panhard rods, and they also have the crossmember that the arms attach to. You might want to look at their offerings.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-06-2010, 04:47 PM | #7 |
Moderator
I'll have some in a week or two...still trying to locate everything. You run out of room quick with the trailing arms, rear end, air bags, shocks, panhard AND trying to fit a sway bar. Forget about the exhaust if you want to see the initial fit-up check out the "project popeye" link in my signature.
09-06-2010, 09:06 PM | #8 |
Has more rust than truck...
Just make sure the trailing arms aren't rusted. I had one fail on my old 70 but it was due to rust around the rivets which allowed the two halves to spread apart.
09-06-2010, 10:30 PM | #9 |
They make a kit that has an adjustable panhard bar, the braket to weld on the rearend for the panhard and the pads that attach to the link bars. I know ecklers has the kit I think it ran around 140 dollars
09-08-2010, 12:25 PM | #10 |
Thanks guys for the info...........Now has anyone thought about making the crossmember with a few more mounting holes? Like an adjustment on the front of a four link setup for traction. My cousin gave me this idea, wonder if it will work? Any suggestions.........
