Hellasick
![]() Join Date: Jul 2006
Door hinge bolt problems
Removed the drivers door today, and had a couple problems. On the lower hinge mount on the cab, the left bolt broke and the right "captured nut" came loose from the hinge mount. Had to grind the bolt head off.
Anybody else deal with this? How to replace the "nut"? I am going to try one of those square bolt extractors on the broken one and try to drive it all the way through. Backing it out sure didn't work.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
#2 | |
Elev8r Man
Re: Door hinge bolt problems
#3 | |
Hellasick
You can just post a pic of it if you find it. I think that that is close to what I've been thinking about since I posted this. Drilling and tapping a thick plate then tacking it in place.
Elev8r Man
Dont tack the plate in place, you need the adjustment for the hinge. I made a cage for the plate to slide for adjustment.
Hellasick
Isn't the adjustment in the hinge itself? The "nut" that came loose was fixed, the other ones don't have any movement.
| Bookmarks |
