Old 09-06-2010, 12:45 AM   #1
po_bird
po_bird's Avatar
Need help converting to power windows
Im wanting to convert my 85 to power windows and lock by swapping the doors off of a 85 silverado. Was wondering if any1 that has already done this would shoot me a few tips before i start.
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
po_bird is offline   Reply With Quote
Old 09-06-2010, 10:06 AM   #2
joe231
joe231's Avatar
Re: Need help converting to power windows
I have done it. It is a fairly simple swap
You just need the under dash harness which will have a door lock relay. the relay can be a pain to get to as it is mounted to the steering column support up under the dash to the right of the column. There are only 3 wires to hook up, all time hot for the locks, a switched hot for the windows, and a ground. The 2 hots should plug into your fuse block (they have special plugs so they will only plug into the correct spot), and there is a ground connection to the left of your instrument cluster that the ground plugs into. You will more than likely need to drill holes in the cab for the wires to pass through. It is much easier to drill with the doors off. If you need anymore info or pics or what-not just give me a shout
CHEVY ONLY
Old 09-10-2010, 10:36 AM   #3
48cj2a
48cj2a's Avatar
Pics would be helpful, wanting to do the same.
How hard is it to pull the harness from the cab pass through?
I just pulled a column from a truck and was going to go back. Cluster was gone, dash pad pulled aleady.
48cj2a is offline   Reply With Quote
Old 09-26-2010, 06:10 PM   #4
48cj2a
48cj2a's Avatar
Got my donor parts for p/w & p/l conversion. Accordian tubes in the door jam came loose perfectly with the gasket scraper/putty knife and hammer suggestion.
The relay above the gas pedal was a bugger but I got it too.
Are there pilot hole dimples in the doors for the p/l actuators?
