09-06-2010, 09:05 PM | #1 |
Bel air
A little off the beaten path here, but I'm looking at a 64 Bel air station wagon, but I cant seem to find any parts on the internet, can anyone of you tell me where I can find parts for these? will Impala parts work for this also? I told him that I was going to do some research before I purchase. it needs to have all 4 doors replaced, one finder, the grille, but the rest is in pretty good shape, pretty sure the gas tank will also need replaced if it can not be cleaned, and I think it is worth he is asking, besides when it is done it should be pretty cool. Thanks.
09-06-2010, 09:11 PM | #2 |
Re: Bel air
OK(lahoma) -
I used to have a 65 Imp and I used Year One as my primary parts supplier. Yes, generally speaking - Impala parts will fit your bel air. Bel Air is just a "less flashy" impala. Fenders, front doors (not sure about the rear doors, but assume yes also), and fuel tank should all interchange. Trim would need to be Bel Air specific, but Year One sells all the Bel Air trim also. I think you might be able to find all you need at Year One. Here's the link if you want to check it out before you buy. jocko http://www.yearone.com/serverfiles/f...ain2.asp?cat=9 |
09-06-2010, 09:47 PM | #3 |
Re: Bel air
Wander around here a bit: http://www.impalas.net
09-06-2010, 10:10 PM | #4 |
Re: Bel air
I thought so, about the Impala, but wasnt sure, Thanks guys
09-06-2010, 10:17 PM | #5 |
Re: Bel air
Also try www.layitlow.com
09-06-2010, 10:50 PM | #6 |
Re: Bel air
09-06-2010, 11:06 PM | #7 |
1961 crewcab
Re: Bel air
I think the front doors will interchange with a 4 door sedan,the rear doors are wagon only(the top window portion is the only difference).
-so you may be able to re skin them with a 4 door skin if that is all that is wrong with them. the fuel tank will be 63/64 wagon only..might be a tough piece to find if it is not reproduced. all the front sheetmetal will interchange off any 64.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 09-06-2010 at 11:12 PM. |
