Old 09-06-2010, 09:31 PM   #1
hdandd
hdandd's Avatar
Question Not 2 happy
My tranny wont shift into 3rd gear anymore... last time it did that it was just out of time but i re timed it and it still wont shift, any ideas?
71 C-15 350 three speed.
hdandd is offline   Reply With Quote
Old 09-06-2010, 09:43 PM   #2
Indyuke
Re: Not 2 happy
What type of transmission?
Indyuke is offline   Reply With Quote
Old 09-06-2010, 09:57 PM   #3
Bad70sbchevy
Bad70sbchevy's Avatar
Re: Not 2 happy
Did you check the transmission fluid level?
Bad70sbchevy is offline   Reply With Quote
Old 09-09-2010, 04:21 PM   #4
hdandd
hdandd's Avatar
Re: Not 2 happy
Turbo hydro matic
Old 09-13-2010, 12:08 PM   #5
hdandd
hdandd's Avatar
Unhappy Re: Not 2 happy
Its not the tanny fluid... it sat for about 18 hours, when i drove it it shifted into 3rd the first time a accelarated but not anyother times..
Old 09-13-2010, 12:16 PM   #6
mr48chev
mr48chev's Avatar
Re: Not 2 happy
Did you knock the vacuum line off that goes to the trans? That happens a lot when a guy is working in that area setting the timing or tightening the distributor down.
Also make sure that the hoses on both ends of the steel line to the modulator are in good shape an not split or swollen and soft.
Old 10-29-2010, 03:43 PM   #7
hdandd
hdandd's Avatar
Re: Not 2 happy
The tranny line is good
Old 10-29-2010, 04:55 PM   #8
planewhisperer
U.S. Army Green Beret Sniper
planewhisperer's Avatar
Re: Not 2 happy
Your vacum line may be cracked or have a hole in it. Do you have vacum advance?
planewhisperer is offline   Reply With Quote
Old 10-29-2010, 05:18 PM   #9
JCD
JCD's Avatar
Re: Not 2 happy
This has happened to me twice.. with a Firebird, and a Corvair..
Someone else will chime in with the correct part name.
It's a sealed plunger that shifts the Trans into high gear..
What happens is, when the fluid is cold, it's thicker, and the plunger works..
But as the fluid heats up it becomes more watery and can no longer actuate the plunger into high gear..
If you're in high gear on the highway or on a road.. the moment the trans kicks down into 2nd, it won't go back up into high gear..
If you let it sit for a few hours, it'll work fine until it heats up again..
J.
1972 Custom Deluxe Highlander C20
1971 Javelin SST New Project
1971 Demon 340
1969 SS El Camino
1968 SS RS 396 Camaro
1967 Barracuda Formula S
1965 140/4sp Corvair Monza Convertible
Sorry, but I don't do Fords.
JCD is offline   Reply With Quote
