Old 09-07-2010, 09:15 AM   #1
Lemield
Lemield's Avatar
Rustoleum Red paint job
I posted some pics in the Body and Paint section but I thought that you 67-72 folks might like to see a couple of pics too.
Six coats of paint applied with a foam roller.....
DISCLAIMER:
My truck is a work truck and I never planned to restore it....I just wanted to make it look a little better for myself and my neighbors.....so.....this seemed like an interesting and inexpensive challenge...I think it looks pretty good...I have not buffed it yet....not sure if I will...
Before and after....
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-07-2010, 09:17 AM   #2
bigguy69
dazed and confused
bigguy69's Avatar
Re: Rustoleum Red paint job
looks good!!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 09-07-2010, 09:58 AM   #3
Racie
Wow...pretty cool for a daily driving work truck...
Racie is offline   Reply With Quote
Old 09-07-2010, 10:20 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Looks a heck of a lot better... About 10 yrs ago I did that to my old 69 that had original patina when one of my sisters told me I needed a new truck. She said that "old thing" was falling apart.
After it gets totally dried out and hardened up I'd at least give it a waxing to protect it from mildew, bird droppings and if you park under some trees, from tree sap.
Rustoleum is pretty hard and durable but some chemicals can leave surface stains. Especially on lighter colors.
68gmsee is offline   Reply With Quote
Old 09-07-2010, 10:35 AM   #5
QKENUF4U
QKENUF4U's Avatar
good ol 10/10 truck. 10mph n 10ft away it looks great... guy back home changes his car colors couple times a year doing it your way...
the bed on my truck is SPRAYED and looks better than the factory paint...
QKENUF4U is offline   Reply With Quote
Old 09-07-2010, 10:37 AM   #6
lakeroadster
Looks good, thanks for posting!
I am wanting to do my truck in red Rustoleum also and really like the way yours turned out.
Could you list specifically which Rustoleum red you used? Was it their "safety red" in their "professional" paint (silver can) or their "red" in the regular paint (white can)?
Did you primer first? If so what product and color primer did you use?
lakeroadster is offline   Reply With Quote
Old 09-07-2010, 10:49 AM   #7
Lemield
Lemield's Avatar
Hi John,
Since you are local, you are welcome to come look at the truck.
I used Rustoleum Sunrise red in the white quart cans. I used about 1.5 quarts. I did not prime it first.
The truck is pretty smooth....I am showing pictures of the nice side...the other side has a BIG dent in it.....
I have about 25 bucks worth of paint invested in the project.
Thanks for the kind words everyone!
Larry
Old 09-07-2010, 11:06 AM   #8
kwmech
Never sprayed a whole truck. But if you use the Safety Red with black primer, you'll get an awesome deep red color
Old 09-07-2010, 11:42 AM   #9
turner15
Ya you can sand and buff that out to look as good as any other paint. I'm doing my square boy flat black with that paint then hitting it with a billo or scotch pad. That look is very cool
turner15 is offline   Reply With Quote
Old 09-07-2010, 11:44 AM   #10
Lemield
Lemield's Avatar
My camera makes the paint look almost orange...but trust me...it's RED....VERY RED.....
Larry
Old 09-07-2010, 12:45 PM   #11
dfwright
dfwright's Avatar
That was $25 + labor that was very well spent! It turned out great!
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 09-07-2010, 01:39 PM   #12
Cdshinne
Cdshinne's Avatar
Glad i caught this thread I need paint on my 72 k20 and i am thinking about going this route since money is tight and i am going to drive this truck in the winter. Is it really as simple as just rolling it on, or are there any tricks to keeping it smooth? What about going with the spray cans?
1972 K20 lwb
2000 Z71 x-cab
1970 ford f100
Cdshinne is offline   Reply With Quote
Old 09-07-2010, 01:47 PM   #13
gregg72340
gregg72340's Avatar
Nice Job, Is there a specific foam roller to use or just a plain old one
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!!
gregg72340 is offline   Reply With Quote
Old 09-07-2010, 01:58 PM   #14
Lemield
Lemield's Avatar
I used the cheap white 4 inch foam rollers from Walmart.....I also used a cheapo plastic roller tray. I ended up using 1.5 quarts of paint total.
The paint will self level if you thin it down to the consistency of whole milk. I just put it on and checked for runs and drips....it takes a little practice to get the technique down. I was able to thin a batch of paint, apply a full coat and clean up in an hour and 15 minutes.....I only put 6 coats on because I got tired of painting.....
I suggest practicing on an old hood or fender......
If you google Rustoleum paint jobs, you will see a lot of info out there....
I have not had good results spraying it....probably because I don't have a paint gun....I did spray can the rockers on the truck since they had some sort of a textured finish on them that the PO applied...I wanted to keep those and put a thicker coat of paint on them for chipping protection....
Larry
Old 09-07-2010, 02:01 PM   #15
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Why six coats? I guess a quarter of a quart per pass is spreading it on pretty thin.
Zoomin is offline   Reply With Quote
Old 09-07-2010, 02:03 PM   #16
Lemield
Lemield's Avatar
When it's thinned, it doesn't cover very well....it takes at least 6 coats to look good with dark colors....at least it did on mine....I wanted to do 8 coats but I was sick of painting and wet sanding.
Larry
Old 09-07-2010, 04:01 PM   #17
Alex Hayley
Subscribing to this thread. I might have missed the answers to my questions. Did you remove the trim? How long did you let the coat dry before applying the next? Did you only wet sand after all 6 coats were dry?
Alex Hayley is offline   Reply With Quote
Old 09-07-2010, 04:04 PM   #18
Lemield
Lemield's Avatar
I masked around the trim because it's a work truck and I'm lazy.
I applied the paint in the afternoon when I got home from work and let it dry 24 hours. I did 2 coats then wet sanded with 1000 grit...then 2 more coats, wet sand again with 1000 grit then two more coats. It still needs to be color sanded and polished.
Larry
Old 09-07-2010, 04:10 PM   #19
Alex Hayley
Thanks! Got more information when I read the other posts you made about your truck. It looks great!
Old 09-07-2010, 04:17 PM   #20
vectorit
What?
vectorit's Avatar
I must say, that when I saw this thread title I was expecting to see something hideous.
But, what you did for your circumstances it really turned out nice!
Being a work truck, I think you went the best route. Plus your time and attention to detail really shows too, and I bet your neighbors appreciate it as well! Which is always a good thing to keep harmony in the neighborhood.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-07-2010, 04:25 PM   #21
Lemield
Lemield's Avatar
Thanks for all the positive feedback folks!
I truly expected it to not look as good as it does.....I honestly thought the whole concept for a roller paint job was hokey....but I figured I really had nothing to lose. From a purely economic point of view, it's pretty hard to beat....
Larry
Old 09-07-2010, 05:01 PM   #22
barryvanhook
barryvanhook's Avatar
If I recall correctly, there was an article in Hot Rod magazine on this very topic 2 or 3 years ago.
Barry
but I think they did a white paint job
Barry L. Van Hook
'69 Chevy Frankentruck
barryvanhook is offline   Reply With Quote
Old 09-07-2010, 05:04 PM   #23
Gene
Gene's Avatar
Wow, just wow.. I expected to see something totally different. Nice job! We sprayed a friends truck back in high school with about 20 cans of Krylon and it turned out kinda sketchy, we called him captain Krylon. Yours looks awesome.
Gene is offline   Reply With Quote
Old 09-07-2010, 06:25 PM   #24
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Larry i think your just posting here to rub it in LMAO...you ve put a ton if confindence in me to get mine done??
one more question..
my truch has some rust pitting will the paint fill those or do I need to do something first??
Hottrucks is offline   Reply With Quote
Old 09-07-2010, 06:36 PM   #25
Shane
Shane's Avatar
paint doesn't fill pits ... it only makes them more visible
Shane is offline   Reply With Quote
