Old 09-07-2010, 12:52 PM   #1
Roland
Junior Member
Roland's Avatar
How do you pick it up
Is there a good point to attach a strap or a chain to be able to lift the engine and trans? This is a 350 LSx and I have chains or straps with overhead hoist or cherry picker, but I don't see where to connect to the engine.
If I run the strap around the whole engine, it interferes with the motor mounts when I set it in the frame. I know this sounds stupid but . . .
Roland is offline   Reply With Quote
Old 09-07-2010, 01:36 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: How do you pick it up
I have one of those levelers with my shop hoist. I bolt one end to each end of both the heads to disperse the load and pick it up that way.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-07-2010, 05:47 PM   #3
Super73
Super73's Avatar
Use 2 chains. Tie one to the front of both heads. Tie one to the back of both heads. Put your hook in the center.
Mine is a little easier with the single plain intake.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-07-2010, 07:03 PM   #4
68GMCCustom
I guess it would have been easier just to say my leveler has 4 ends that attach to the end of each head... then attaches to the crane hook, with a crank system to level things out.
Have you ever lifted by the intake Super73? I've seen the plates....but I'm afraid its too much weight for the small intake bolts to hold...especially is theres a trans on the back.
Kurt -
Old 09-07-2010, 07:22 PM   #5
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I hooked my leveler in the 4 corner valley pan bolt holes with longer bolts with standard size heads and thick washers. Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 09-07-2010, 08:21 PM   #6
TR65
TR65's Avatar
I tried to simulate the factory type lifting arms that bolt to the heads.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 09-07-2010, 08:58 PM   #7
Roland
Junior Member
Roland's Avatar
Thanks TR65, this looks like a good solution.
Old 09-07-2010, 10:08 PM   #8
Super73
Super73's Avatar
I have used the 4 bolts on the carb plate many times with my alum LS1. I'm trying to remember if I have ever done it with the trans attached. I don't think I have. I can tell you though, my fully dressed LS1 with water pump alternator ect weighed in right at 400lbs. My 80E when on the pallet with factory verter weighed in at 270lbs. I have seen people pull traditional SBC's with transmitions on them with a carb plate on an alum intake and they have to weigh more than my junk.
Old 09-07-2010, 10:53 PM   #9
68GMCCustom
it just seems the LSx intake bolts are too small to handle that kind of load. Guess not.
Kurt -
Old 09-08-2010, 09:03 AM   #10
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
I just run my short dedicated engine hoist chain from one head to the opposite corner of the other head. I had the intake off at the time, but this is the way I have always done it, SB and BB too.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 09-08-2010, 09:15 PM   #11
TR65
TR65's Avatar
Just for reference,
Here is the factory style lifters, lifted engine and tranny. I couldn't find any source for these at the time.
TR
1965 C10 SWB Fleet
Two owner
Old 09-08-2010, 10:22 PM   #12
68GMCCustom
IIRC those have 2 bolts each...so it would be about the same as one bolt per head at the 4 corners.
Kurt -
Old 09-08-2010, 10:41 PM   #13
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I used 1 chain from the bottom alternator bolt with an eyelet off of it to the rear opposite head.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 09-09-2010, 12:49 AM   #14
Super73
Super73's Avatar
TR65, That sure looks like a truck motor with a 6 speed trans.. Never seen that before..
Old 09-09-2010, 10:52 AM   #15
68GMCCustom
Ssr?
Kurt -
Old 09-09-2010, 11:06 PM   #16
TR65
TR65's Avatar
Yep, 2005 SSR (6.0L, 390 HP).
Seems like a perfect swap for an old truck. By the way, the SSR weighs 4750#. More than 1200# more than my 65.
TR
1965 C10 SWB Fleet
Two owner
Old 09-10-2010, 10:06 AM   #17
68GMCCustom
I may have asked this before...but have you taken it to the track?
Kurt -
Old 09-10-2010, 08:48 PM   #18
TR65
TR65's Avatar
68,
No, I am just using it as a fun DD and trying to get high mpg. It will sure get on with the program though.
TR
1965 C10 SWB Fleet
Two owner
