Old 09-07-2010, 07:41 PM   #1
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Dorman pins/bushings 83 Chevy
I picked up the Dorman 38400 pin/bushing kit and have put the bushings in but the pin is being a little difficult. What's it take, a BFH, or some kind of press? Was using a hammer but doesn't seem to want to go and I don't want to bend the hinges. Was thinking maybe a large C clamp might get the job done. Any tricks to this? Thanks
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 09-08-2010, 12:52 AM   #2
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
Re: Dorman pins/bushings 83 Chevy
here is a bump for ya. if this don't work I would have it moved to the body forum.
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 09-08-2010, 08:19 AM   #3
Seven9er
Seven9er's Avatar
I heated up the hinge bracket with a propane torch put the bushing on and one smack with a decent ball peen and it was in. you might have to put some pliers on it so it doesnt bend but I ddnt run into any issues.
USMC Former SGT 2002-2006
Oshkosh Truck Corporation- FSR, The worlds largest manufacturer of Severe Duty Trucks.
The Money Pit. http://67-72chevytrucks.com/vboard/s...d.php?t=406891
2009 2500HD R.I.P. http://67-72chevytrucks.com/vboard/s...12#post4025612
Seven9er is offline   Reply With Quote
Old 09-08-2010, 08:38 AM   #4
nlped
nlped's Avatar
I cut the original pins in half while it was still in the truck, and then they came right out. Much easier, and no chance of bending the hinges.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-08-2010, 10:06 AM   #5
WestButteTruck
Kung Fu Master
^^ Used that trick when taking them out. But now I have everything back together aside from getting the pin seated all the way. Where the splines are at the top of the pin, it just wont go in any further. I'm going to try and support just under the hinge with something, then give it a whack with a hammer again. Maybe there is too much bounce without any support under it?
Old 09-08-2010, 12:36 PM   #6
nlped
nlped's Avatar
This is how I put the new ones back in, if this is what you are trying to do.
Carter
Old 09-08-2010, 02:10 PM   #7
WestButteTruck
Kung Fu Master
I had done a search and found your pic before I started so I did that with the bushings. Thanks. But now getting the pin to go all the way in was kind of a bear. So what I did was used my floor jack, a piece of 4x4 lumber, and a socket and gave some support under the hinges and it finally went in. I will try and post of pick of what I was doing. I still have 3 pins to go, but need a run to the parts store to get them.
