09-07-2010, 09:08 PM | #1 |
new guy with a question
I'm very new to the site and thought I should introduce myself. I picked up a '72 earlier this summer and found this site to be an excellent source of info. One of the first things I did on the truck was pull out the dash cluster and fix the gauges and lights as the only thing working was the speedo. I tracked down everything posted on how to tell if the gauge was working and ended up only needing to replace the float on the sending unit. Anyway, I really appreciate all of the knowledge that is shared here. Sure helps out.
here's a picture of the top of the gas tank. Any idea why the PO would block one line? |
09-07-2010, 09:11 PM | #2 |
Its a Truck Thing......
Re: new guy with a question
Unless the vent lines that run up the cab are broken, I really dont understand why either.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
09-07-2010, 09:44 PM | #3 |
Junior Member
A lot of people remove the charcoal canister and block off that connection on the tank. Then install a vented gas cap.
I left the hose on my tank to act as a vent for the tank on my '71 since the gas cap on it is of the non-vented type.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
09-08-2010, 12:02 AM | #4 |
DON'T TREAD ON ME
I don't know about your question but WELCOME to the forum.
Old Yeller |
09-08-2010, 09:45 PM | #5 |
Hey shyguy, what do you mean by a charcoal filter? I disconnected the other line, unbolted the vent piece but it's just a looped fuel line. where is the filter?
09-08-2010, 09:57 PM | #6 |
Junior Member
The charcoal cansiter filter thing is inside the passenger fender at the very front by the battery.
I imagine there are people with these trucks that don't even know they are there. I think they are '71 and newer trucks that have them and I have found not all of them have them.
09-08-2010, 11:35 PM | #7 |
is it necessary to run a charcoal canister if your truck came with one or can u just bypass it.
1972 chevy c 10 longbed 2000 Ford Powerstroke (daily driver) Last edited by Seraph; 09-08-2010 at 11:36 PM. |
09-09-2010, 12:00 AM | #8 |
never mind the answer i was looking for was in a previous post......i must be really tired...
1972 chevy c 10 longbed 2000 Ford Powerstroke (daily driver) |
09-09-2010, 02:08 AM | #9 |
Old member
The line that is plugged is the cab line that runs up into the top passenger side of the cab. I would think the only reason to do what he did was he was getting fumes out of it when the tank was full and getting hot. Most fumes are from the gas tank cap itself though not those lines.
