Old 09-07-2010, 10:22 PM   #1
Southern C10
Is it done yet?
Southern C10's Avatar
New Project help: Whats the difference in 47-53 Chevy trucks?
I am looking at starting another project and wanted to know if there is a comparison write up or something showing the difference's in the 47 thru 53 model Chevy trucks or if there is no differences at all.
Thanks, Brian
1972 Chevy SWB
New 383 Stroker/350 Turbo
Some day i'll paint it
John 3:16
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=398108
Southern C10 is offline   Reply With Quote
Old 09-08-2010, 01:07 AM   #2
nebdrummer
nebdrummer's Avatar
Re: New Project help: Whats the difference in 47-53 Chevy trucks?
the brothers trucks magazine had a good write up of it. i cant find it right now but if i do, ill post up.
this is just off the top of my head.. so it could be a bit wrong
47-48 had bed tanks
51 had push button handles and 1 pc window
52 had push button handles with smokers window
54 the obvious grille, dash, bed difference
somewhere between 51 and 53 i think they removed the drivers side cowl vent.
then throughout the years the bed wood/strips differ a bit.
soem years, had thriftmaster with the hood side emblems, some didnt.
then some had a maroon knob on the cowl vent handle.
just a bunch of odds and ends stuff like that.
like i said, thats what i can come up with. i might be wrong about some of it, but i know its close.
also, 3/4 tons had narrower frames than 1/2 tons. and the 1/2 ton frame is about 2 inches closer to the bed wood than the 3/4.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit!
http://67-72chevytrucks.com/vboard/s...d.php?t=380212
nebdrummer is offline   Reply With Quote
Old 09-08-2010, 03:37 AM   #3
55dude
55dude's Avatar
47 had lever shocks still. 47'-50' had "pull down" door handles.
55dude is offline   Reply With Quote
Old 09-08-2010, 07:35 AM   #4
Dan Bowles
AD Addict
51 had pull down handles, not push button. Those came out in '52.
47-48 has a different inner structure behind the seat and a "dip" in the cowl center under the hood. No "H" ribbing in the cowl above the steering box. "Crotch cooler" side vent on driver's side. 1 piece glass doors.
49-50 has H, crotch cooler, 1 piece glass doors, turn down handles.
51 H, no crotch cooler, vent windows, turn down handles
52-3, H, no CC, vent windows, push button handles
54 is the best and most beautiful. 1 piece windshield, different dash, gauges changed. Push button doors (interchange 52-54). Grille change as well. Front fenders change to accept grill but will bolt on older trucks. Flat top bed is deeper. Frame changes. Trans/motor support changes (hydromatic available)
55S1, carry over 54 for 3 months of 55. Open driveline, different emblems.
Emblems change throughout the series.
Dan Bowles is offline   Reply With Quote
Old 09-08-2010, 09:09 AM   #5
Southern C10
Is it done yet?
You guys are awesome. Any pics of the push button doors? I am venturing over from the 67-72 side of the house and am not familier with alot of the details of these trucks.
Thanks, Brian
1972 Chevy SWB
John 3:16
MY BUILD THREAD
Old 09-08-2010, 06:32 PM   #6
Dan Bowles
AD Addict
Stovebolt.com
Look at the Gallery. You can go year by year.
Old 09-08-2010, 08:14 PM   #7
nebdrummer
nebdrummer's Avatar
^yup, you are correct.
i knew something changed in 51, and yeah, it still had turn downs and vent window.
Old 09-09-2010, 10:56 AM   #8
av8tr33337
av8tr33337's Avatar
The 51 was the last year for turn down door handles and the first year for wing windows. To my mind that makes in unique (the missing link) That's what I'm working on.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 09-09-2010, 11:17 AM   #9
MrTucker
MrTucker's Avatar
read the discription on the inside cover of the LMC catalog - it goes pretty in depth on the year to year differences
1953 GMC 1/2 ton long bed
Original 228 I6 with a Hydramatic Auto Tranny
Project Pack Rat - http://67-72chevytrucks.com/vboard/s....php?p=3374649
MrTucker is offline   Reply With Quote
Old 09-10-2010, 09:26 AM   #10
Dan Bowles
AD Addict
It has been a while but I thought there were some errors on the LMC list. That and some missing items. Still, it is a good start.
Does anyone know how to tell if the ID tag for the '47s is for an Art Deco or Advance Design?
Old 09-10-2010, 09:41 AM   #11
av8tr33337
av8tr33337's Avatar
Here is another link that may help you out
http://www.stovebolt.com/techtips/VIN.htm
av8tr33337
1951 3100 Pickup
Old 09-10-2010, 11:18 AM   #12
Dan Bowles
AD Addict
Doesn't help me: For the '39-'46, it should be found on the right side of the cowl, under the hood. Advance-Design ('47-'54) and later trucks should have a plate located on the left front door post.
I've got a loose '47 GMC plate but don't know if it is an AD or an AD! Or did GMC even make the cross over year like the Chevies in '47?
Old 09-10-2010, 12:41 PM   #13
T Hilde
When did they make the switch? I would think by running the VIN it tells you the date of manufacture.
T Hilde is offline   Reply With Quote
Old 09-10-2010, 01:29 PM   #14
Dan Bowles
AD Addict
That, I don't know!
