Old 09-09-2010, 12:11 AM   #1
69GMC910
MOTORHEAD!
69GMC910's Avatar
Tubbing?
Does anyone sell the wheel well tubs or are they a custom mod usually? Looking at tubbing my 69 lwb....
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 09-09-2010, 12:22 AM   #2
70cst
70cst's Avatar
Re: Tubbing?
I just did a search w/o any hits so maybe someone will chip in with info.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 09-09-2010, 12:24 AM   #3
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Tubbing?
Here's hoping!!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 09-09-2010, 12:33 AM   #4
70cst
70cst's Avatar
Re: Tubbing?
Here you go...
http://www.jegs.com/c/Wheel-Tubs/100...7-bc510d253e51
Old 09-09-2010, 12:36 AM   #5
Rideto100
Rideto100's Avatar
Re: Tubbing?
Just take two original inner wheel wells and cut and splice them together, it almost looks as if it could have been factory.
Rideto100 is offline   Reply With Quote
Old 09-09-2010, 07:38 AM   #6
bigsnookmaster
bigsnookmaster's Avatar
Re: Tubbing?
If your'e doing a fleetside, the originals stretched, look good. This takes a donor set to make. Stepsides look better with aluminum or steel rounded IMO. Here's a pic of the ones in my stepside, we custom made out of polished 16gu. stainless, "not cheap".
bigsnookmaster is offline   Reply With Quote
Old 09-09-2010, 08:05 AM   #7
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: Tubbing?
check my build....what I did was cut about an inch from the bed wall this leaves your flange that bolts on I cut it out to the 3rd flat spot on the floor then flattened out the floor where the wheel well will lay on the floor place the tub down and cut a piece wide enough to go from the bed wall to 1" over the tub make the bends for the tabs on the floor then start at one end and work it over the tub spot welding as you go till its done. This only leaves the 1 seam ...a little seam sealer and some paint and your done...you could butt weld them if you wanted but the seam is straight so it looks clean..be sure to do the inside of the tub too!!
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 09-09-2010, 10:17 AM   #8
QKENUF4U
QKENUF4U's Avatar
Re: Tubbing?
QKENUF4U is offline   Reply With Quote
Old 09-09-2010, 10:21 AM   #9
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Tubbing?
I think this is the only way to go and you don't fight trying to get it to form to the bedside. Here is a VERY roughed-in look at mine.
Really the toughest part will be taking the last raised part of the bed floor and cutting/forming it to look like the other 2. My build thread shows how I did mine and it looks pretty darn factory.
prostreetC-10 is offline   Reply With Quote
Old 09-09-2010, 08:15 PM   #10
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Tubbing?
Thanks everyone! I think the donor wheel wells is the way I will go as I have access to a donor truck!! Can you also give me an idea of what else I'm going to have to do to run a 31x 18 x15 tire? My truck has coils in the rear? A narrowed 9"? Eaton? Detroit? What all has to be relocated?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 09-09-2010, 08:41 PM   #11
QKENUF4U
QKENUF4U's Avatar
Re: Tubbing?
i used a stock rear with 15x14 rims w/ 10bs... fit perfect w/ 31 x 18.5 x 15 tires...
no longer have truck but i do miss it.....
Old 09-09-2010, 08:47 PM   #12
69GMC910
MOTORHEAD!
69GMC910's Avatar
Re: Tubbing?
what is the offset on the rims?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Hooker 2455's
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Old 09-09-2010, 09:18 PM   #13
bigguy69
dazed and confused
bigguy69's Avatar
Re: Tubbing?
what kind of hubcaps are those look good!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 09-09-2010, 09:45 PM   #14
prostreetC-10
My Carbon Footprint
Re: Tubbing?
They almost look like either policy ralley caps or corvette disc brake caps.
