Old 09-09-2010, 01:24 AM   #1
coreyslude
Another question about 73-87 crossmember
I have a 67 c10 and plan on using a 76 front crossmember that I already have. My question is will lowering springs for 67-72 trucks work with it or do i need springs specifically for the 76? I ask because you can buy kits with front and rear springs shocks etc.
coreyslude is offline   Reply With Quote
Old 09-09-2010, 05:18 PM   #2
SCOTI
SCOTI's Avatar
Re: Another question about 73-87 crossmember
Yes, they will interchange. Why are you swapping the x-member?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-09-2010, 07:19 PM   #3
brans72
Guessing for the disc brake set up? I know I am using a 83 front end for the disc brakes on my 67 so having to swap complete cross member over.
brans72 is offline   Reply With Quote
Old 09-10-2010, 12:07 AM   #4
SCOTI
SCOTI's Avatar
Just to make sure you guys are aware, there is no need to swap the x-member unless you want to. All the disc swap parts will work on the existing x-member.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-10-2010, 12:38 AM   #5
coreyslude
Am gonna swap for the disc brakes. And thanks for the replies, just wanted to make sure I order the right parts.
Old 09-10-2010, 12:51 AM   #6
coreyslude
So if I just swap all the parts to my 67 crossmember I would use drop spindles I assume for the 73-87 and could use the springs for the 67-72 trucks? Im wanting to do a 3 and 5 inch drop.
Old 09-10-2010, 06:06 AM   #7
brans72
you can swap all 83 brake parts to a 67 without changing crossmember?
Old 09-10-2010, 09:00 AM   #8
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
I believe all you have to do is drill out the lower control arm mounting holes, the u-bolts that hold the cross shafts are bigger on the newer control arms.....I think ??? That being said I still put the entire crossmember under mine..... just because....!!!!
ksbrktracer is offline   Reply With Quote
Old 09-10-2010, 09:18 AM   #9
SCOTI
SCOTI's Avatar
The bigger u-bolts came standard when the factory switched to discs; the a-arm shafts are the same size. So technically the smaller dia u-bolts will retain the later model a-arms as is it's just smart to drill the holes out for the larger dia u-bolts.
Drilling the holes out is only required if desired. A guy can swap the disc brake parts to his original a-arms w/no issues.
Coreyslude, if there's confusion about what is needed, check out the suspension section. There's multiple threads w/all the info needed for a swap to discs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
