Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 09-09-2010, 12:12 PM   #1
JimmyFloyd
86 Rear End D60?
Ok, I found this rear end under an 82 or 86 pickup, one ton I believe. It's 8 lug, heavy duty springs, huge drums and it's a Posi. It said 60F on the lower pass corner of the pumpkin I believe.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 09-09-2010, 04:21 PM   #2
JimmyFloyd
Re: 86 Rear End D60?
Ok, looked at it closer. Might be a 14BFF based on the cover. Not sure.
Also, is that factory rear swaybay worth anything? Thinking about grabbing the whole setup for my blazer if it will be better than what I have (12bolt, 6 lug, open)
Old 09-09-2010, 05:48 PM   #3
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
I think you're right on the 14 bolt.....
http://coloradok5.com/axleguide.shtml
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 09-09-2010, 06:53 PM   #4
Pop's C-10
Pop's C-10's Avatar
grab both bars
Pop's C-10 is offline   Reply With Quote
Old 09-11-2010, 12:23 PM   #5
USSkoval
The rear is worth about $100, maybe closer to $150 if it has good gears (like 4.56).
I'm not sure, but the rear swaybar setup might be worth as much as the rear. Not many trucks had it, and the ones that did probably don't anymore (like my '79 camper special). It probably can only be used on a 1ton though because of the perch spacing.
That truck also has the equipment for a slide-in camper.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
