Old 09-09-2010, 12:17 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
What psi do you run?
What psi do you run in your tires on-road. We run 5lbs less than max in the BFG A/T's on the Suburban. Thats what I do on all my vehicles, better mileage and tire wear.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 09-09-2010, 04:50 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: What psi do you run?
I use a tread depth gauge to help determine correct pressure, and I rotate regularly to even out the wear. My K20 gets 30# unless I'm cutting firewood, then the fronts go to at least 35# and the rears get 50#. The Tacoma gets 32# all around.
The right pressure varies with vehicle weight, how it's driven, size & type of tire, and probably a few other factors...
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-10-2010, 12:46 PM   #3
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
I was told to use sidewalk chalk on a flat parking lot... Cover a large patch on each tire, then drive 50 feet or so and see if it all wears off or not. Also good way to check toe alignment...
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 09-10-2010, 01:26 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
^ The chalk method is a good start, but only for straight-line driving. If you do a fair amount of cornering, you'll need more pressure to avoid excessive wear on the outer edges, especially on the fronts. That's why I use a tread depth gauge -- it will find differences that are too small to otherwise notice.
- Mike -
RIP El Jay
Old 09-10-2010, 10:15 PM   #5
Davetopay
My Co-op bias plys are kept at 40psi front and back on road and I usually drop them to about 20psi off the road.
Davetopay is offline   Reply With Quote
Old 09-10-2010, 10:30 PM   #6
donut
donut's Avatar
My tires are 80 psi max. IIRC, the rears are at 70, fronts are 45-50. 70 in the front was too harsh a ride without the plow on.
Treadwear still looks good, but I don't think I've put 3000 mi on it yet.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 10-06-2010, 10:31 AM   #7
81k10
81k10's Avatar
less pressure than max will give you less mpg because it causes more rolling resistance because of more tire on the flat surface of the ground. but at only 5lbs less it wont cause the tires to wear any less but it doesnt help either. just my $.02
current trucks=
-DD 90 RCSB 4x4 350/700r4 (green goblin)
-87 RCSB 4x4 on 3/4 tons. 355/built 700r4.np208(soon to be 205). 10 bolt front 3.73s. 14ff rear 3.73s. 6inch suspension 3inch body. 37x12.50 Wrangler m/t military's. (sinister 13)
Past 73-87s=
-81 RCSB 4x4 built 350/SM465/205. 6inch suspension. 35x12.50 courser a/t's. 4.11s f/r (ravvid red)
-80 RCLB 4x4 454/350/205. 6inch suspension 3inch body. 38.5 gumbos. (mudslut)
17 years old. have had 13 different vehicles. no wrecks.
81k10 is offline   Reply With Quote
Old 10-07-2010, 09:08 AM   #8
Davidmichael
Davidmichael's Avatar
I run mine at 30 and am going to go up to 40 and test that out. trial and error for me here.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 10-07-2010, 10:42 AM   #9
snj8198
snj8198's Avatar
Determining proper tire pressure is kinda tricky. Alot of things come into play when figuring what is proper presssure like tire size, side wall ply and rating, wheel width, front/rear weight of vehicle, load carried, etc even time of year. Ultimately your tire and vehicle will tell you what's needed, ya just need to read and listen to it.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
