Old 09-09-2010, 02:41 PM   #1
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Angry running rough
On my way into work, my truck started running rough. It feels like it is possibly missing and the exhaust smells strong.
I won't have time to look into it until this weekend, but I was hoping to get some possible starting points. It is a bone stock 350.
  • Wires
  • points
  • plugs
  • carb (I just filled up so bad gas?)
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-09-2010, 03:56 PM   #2
jaros44sr
jaros44sr's Avatar
Re: running rough
  • Wires
  • points
  • plugs
How about an easy one...fuel fiter?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-09-2010, 04:52 PM   #3
1949gmc
Re: running rough
Yeah, my first thought was fuel filter, too, especially since you just put gas in it. It's an easy change, but if it doesn't do it, I'd look at plugs/cap/rotor next.
1949gmc is offline   Reply With Quote
Old 09-10-2010, 11:40 AM   #4
bouncytruck
SKINNY TIRES RULE!
Re: running rough
Good call on the fuel filter. I'll start there tomorrow.
bouncytruck 1972 K5
Old 09-10-2010, 01:24 PM   #5
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Re: running rough
You could have had a plug wire pop off too, or get next to the manifold. I've had that happen before.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 09-10-2010, 04:41 PM   #6
jaros44sr
jaros44sr's Avatar
Re: running rough
Great possibility, good call...easier to start with the simply stuff
SAFETY FIRST
AS usual, off topic
Jim
Old 09-10-2010, 09:09 PM   #7
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Re: running rough
When I read exhaust smells strong...I thought ignition. I'd bet it's got carbon build up on the contacts of the cap. Go ahead and go pop the cap off and check to see how much crap is built up.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 09-14-2010, 11:07 AM   #8
jaros44sr
jaros44sr's Avatar
Re: running rough
any updates??
SAFETY FIRST
AS usual, off topic
Jim
Old 09-14-2010, 01:26 PM   #9
bouncytruck
SKINNY TIRES RULE!
Re: running rough
I changed the cap and rotor, checked the plugs and wires and it seems to be running much better. I bought a fuel filter too, but I haven't had a chance to install it.
I did notice that the wires on the passenger side were off the wire holder thing above the valve cover. I've got the wires in the stock routing and wire retainers so I don't think anything was touching the block or exhaust.
bouncytruck 1972 K5
Old 09-14-2010, 04:33 PM   #10
jaros44sr
jaros44sr's Avatar
Re: running rough
when it gets dark tonight, go out and fire it up, see if any arcs appear...hope you found it with the tune up
SAFETY FIRST
AS usual, off topic
Jim
Old 09-14-2010, 04:42 PM   #11
RED72blazer
urban fourwheelin
Re: running rough
are you still running points?
Old 09-20-2010, 12:04 AM   #12
red71cheyenne
Back in the sticks
Re: running rough
Bouncy, did you get it figured out?
2011 K1500 Suburban
2014 K1500 Pickup
