Old 09-09-2010, 03:43 PM   #1
ROBO66
ROBO66's Avatar
Question Rear 6" drop/Front 4 1/2" drop.
Hello all. I am in the process of a 67 SWB build. I already have a front end with 2 1/2" drop spindles and 2" drop springs (4 1/2" drop in front). I have a leaf spring rear end and wanting to drop the rear 6". Can this be done using the existing leaf springs, without "c-notching" the frame? Just some additional information; the rear end I went with is a Ford 9".
Feedback would be greatly appreciated.
Thanks, ROBO66
ROBO66 is offline   Reply With Quote
Old 09-09-2010, 04:22 PM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Rear 6" drop/Front 4 1/2" drop.
That much drop can be done on coil spring trucks without a c-notch, but that's about the limit.
Zoomin is offline   Reply With Quote
Old 09-09-2010, 06:35 PM   #3
bovey
bovey's Avatar
I'm running a 6" drop with coils and ended up having to notch the frame to avoid banging on larger bumps, let alone putting anything in the back.
bovey is offline   Reply With Quote
Old 09-09-2010, 07:02 PM   #4
Blackjeep99
I have a 69 GMC swb with leafs. I did an axle flip and got 6in drop but u have t C-notch the frame. Its really not hard I did mine with cpp bolt in kit nice kit it worked great. I did mine by myself in abouT 16 hrs but I bolted and weld the kit. But if u notch rember the brake line I cut thru mine lol that added a bit mor time to the work. and u can pull the axle out and get it all painted up nice and purrdy wile ur at it. Also I moved the axle back 3\4 in to center the weel in the well. I had bout a$180.00 in it all together including paint and new brake lines. Hope I helped
Blackjeep99 is offline   Reply With Quote
