Old 09-09-2010, 07:59 PM   #1
Born Lucky
What would you do?
O.K.
So, in my normal routine of upgrades, resto, etc. I more than likely buy new fasteners for my parts. This usually changes if the vehicle is new or close to new.
Is this overdo! Example: I am redoing my coolong system, new hoses, new thermosat, water pump. I plan on using all new hardware for this application.
I like to do this because I feel the fasteners are old. Metal changes after all this time.
What are your habits when it concerns this?
P.S. All fresh paint also! I do it right.
Born Lucky is offline   Reply With Quote
Old 09-09-2010, 08:24 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: What would you do?
I generally use new fasteners as well. I also frequently upgrade to serrated flange nuts and bolts on sheet metal connections. If I was a restorer I would stick with nothing but originals. New reproductions for a specific application rarely ever look like the originals. I've always used the cars and trucks I've built, so functionality has always been more important to me than correctness.
Old 09-09-2010, 08:38 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
I like to bead blast them clean and put them back where they belong.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-09-2010, 11:59 PM   #4
Captainfab
60-66 Nut
I often use new fasteners too, but it sometimes depends on what it is, and the budget at the time. Another consideration is the fact that these fasteners have held up this long, and they are made in the USA. Most, not all, of the new fasteners that you will buy are made in China or some other foreign land. I know they have to pass QC and all, but I just don't have 100% faith in overseas products. So if the original fasteners look to be in good condition, I will most often reuse them. But then again like I said, it depends on the application. For a performance engine build, I will replace at least the critical fasteners with quality made fasteners.
Old 09-10-2010, 04:13 AM   #5
blackedoutharley
On engines I always replace the fasteners... Anything with some "poop" to it gets new main and head bolts.
blackedoutharley is offline   Reply With Quote
Old 09-10-2010, 08:53 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Any fastener that'll 'stretch', and has a crutial torque spec (heads, mains, rotating assemblies, etc.) will be replaced.
As Captain and others mentioned, I would clean up and reuse. Unless, previous owners went thru the vehicle, and the fasteners are mis-matched etc.
If I'm doing a custom build on something (whether I'm changing out to an aluminum radiator, or adding a new manifold, or some V covers) then I will usually change out all the fasteners to new. I usually save all the old stuff though.
I'm a big fan of the look of the grade 8 stuff ...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-11-2010, 01:10 AM   #7
apachedaddy
apachedaddy's Avatar
I'm sure most wrench turners have a bucket of these. Over the years of works on trucks and cars my 2 gallon bucket has filled with nuts, bolts, washers and such. I can't tell you how many times I dumped it on the floor and found, cleaned up and used hardware out of it. As stated before some things are best bought new but I recycle other items that can be... As my grandpa use to say if you don't have left overs you didn't do it right LOL...
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 09-11-2010, 09:23 AM   #8
losthope
losthope's Avatar
i dump my coffee can on the garage floor often!!
losthope is offline   Reply With Quote
Old 09-11-2010, 10:58 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
When ever I do a water pump I usually replace the bolts with SS bolts.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-11-2010, 12:55 PM   #10
sams60gmc
sams60gmc's Avatar
95 Percent of my bolts will all be new. Thankfully I have access to a huge assortment of grade 8 bolts and an even bigger assortment of grade 5. I perfer 8 tho because they are coated.
Body bolts will most likely be cleaned and re used.
I also perfer fine thread. I don't know why. Just like the look more.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
