09-09-2010, 09:34 PM | #1 |
Sofa King Crazy!!
Help with the Power Steering Pump
I installed PS on my 67 and cannot figure out why the bolt in the back on the bottom is leaking. I did put teflon tape on it, to no avail, it is leaking again. Please give me a little knowledge about stoppin the leak!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
09-09-2010, 10:50 PM | #2 |
Old member
Re: Help with the Power Steering Pump
Just guessing here but are the threads messed up on it? Also is the teflon tape installed on it correctly? Yes there is a right and wrong way to install the tape.
You want the tape in the oppisite direction on the threads, in other words say you are holding a bolt in your right hand it would turn to the right to install it...correct, the tape should be wrapped in the other direction as if you are wrapping it up. Hold end of teflon tape to the bolt threads and rotate the bolt as if installing it. This will keep the tape from bunching up when you do install it. If this is all done right and it's leaking still then I'd say you have a bad pump and need it replaced.
09-09-2010, 10:58 PM | #3 |
Back in the sticks
Also check the flare. It could have a crack in the pipe and it is weeping regardless of how tight it is.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
09-10-2010, 12:28 AM | #4 | |
Sofa King Crazy!!
I will do so. Just wanted to try fixing the prob without taking the pump off. Oh well....what's another hour after almost 2 years!
