Old 09-10-2010, 12:07 PM   #1
Overdrive
Sawzall User
Overdrive's Avatar
Location: The snow infested Prairies of Canada (aka: Winnipeg, Manitoba)
Question Blazer/Suburban Filler Neck on truck
I've searched high and low and I haven't seen any info in this. Has anyone installed a Blazer tank in a truck and used the Blazer filler neck, and in-bed cover? I'm looking to do this to my truck, but I'm not sure if this will work with the wood bed floor. I need to install a new floor anyhow, so if I need to move cross sill, etc, I'd be interested in knowing before ordering a wood kit.
How about a Suburban filler neck and body side cove?
I'm still going to use this truck as a truck, so the filler through the bed floor is not an option for me.
'67 GMC 910
Overdrive is offline   Reply With Quote
Old 09-10-2010, 03:53 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Blazer/Suburban Filler Neck on truck
Most want something a bit cleaner than the Blazer/Burb gas filler.It just looks like a truck filler in a different spot.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-10-2010, 05:09 PM   #3
ERASER5
ERASER5's Avatar
I'm on board with ya. For a work truck, I think your idea would be great! It would look better than the cut in square doors used on most of the vintage saddle tank installs. It looks just fine on burbs and blazers, so why not?
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 09-22-2010, 10:44 AM   #4
67chevy2wd
67chevy2wd's Avatar
I am not sure what a blazer or suburban filler neck looks like exactly but on my 71 there is a bed side fill cap that looks like a burb fill from what I know. It is just located towards the front. I will get some pics for you today since I am in the process of removing the wood floor to install a steel floor. I don't plan on getting rid of the filler neck because I use the bed too it only has a 15 gal tank.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
