02-25-2003, 12:24 AM | #1 |
what size
what size driveshaft do i need for a longbed with a stick and also how much trouble is it to replace an automatic with a stick and i was also told one time that i can put the stick in without modifing the tranny hump but it would just be a tighter fit is this true? all help is highly appreciated
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
02-25-2003, 12:31 AM | #2 |
Used to have a truck
I think I had to lop 9 inches off my driveshaft when I installed a TH350 . My motor is set back in the big block position though so its a bit farther back than yours is although the inches getting chopped should be the same. If your going to 4 speed ( truck ) from an auto you just need to add some. Easier and cheaper to get one out of the junkyard IMHO.
I think you'll need a hi hump if you go to the 4 speed. there will be a lot sticking up through the center if you dont. At least the NP435 needed one.
No truck :-( Last edited by mikep; 02-25-2003 at 12:33 AM. |
