Old 09-10-2010, 02:54 PM   #1
BluTrukker
BOHICA
BluTrukker's Avatar
body panel adhesive opinions
The PO replaced the outer rockers and cab corners on my 68 about 4 years ago. He used body panel adhesive instead of welding them in. I inspect the seams occasionally, and it seems to be holding up pretty well. I have not found any cracks or separations. I plan on repainting the truck in the next year or two, depending on time and money. While I have it stripped, should I go ahead and weld it or do you think it will stand the test of time?
Trying to save someone from their own stupidity is like teaching a pig to dance. It is a waste of your time, and it annoys the pig!
BluTrukker is offline   Reply With Quote
Old 09-10-2010, 05:06 PM   #2
LONGHAIR
Re: body panel adhesive opinions
"Done properly" the adhesives that are designed for body panel bonding are just as strong as welding. The real issue is "done properly". The correct fit, contact area, cleanliness, clamping, are all very important. That being said, I don't think any of the companies that make the stuff recommend it's use on structural parts.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-10-2010, 10:43 PM   #3
phipp13
THE DAMN YANKEE
phipp13's Avatar
i used 3m panel bonding adhesive on my new roofskin and i have to say i'd do it again it was well worth it imho. the 3m is expensive though. i just did"nt want weld shrinkage. got pics on my build page. good luck phipp13
phipp13 is offline   Reply With Quote
