09-10-2010, 10:04 PM | #1 |
Wheel Spacers
I was going to put 1 1/4" wheel spacers on the back of my C20 so they rears are even with the fronts. Having never used them, how do they work? Won't the lug studs stick out too far? Do you have to cut them off? Just curious...
09-10-2010, 10:28 PM | #2 |
Re: Wheel Spacers
Most quality spacers will bolt to your existing lugs with nuts and then will have it's own studs that will be attached to the spacer. Many of my friends have used the spidertrax spacers on their jeeps and they are top notch quality. But if you are only needing a 1/4 inch or so you can't do the bolt on style. Hopefully some of that made sense.
09-10-2010, 10:57 PM | #3 |
Re: Wheel Spacers
I'm planning on 1 and 1/4 inch. It is the studs on my axle right now I'm worried about. I guess if they are less than 1 1/4" I am fine but they seem longer. Thanks for the reply
09-10-2010, 11:11 PM | #4 |
Re: Wheel Spacers
I have been running spacers on the rear of My 70 4x4 for over a year for that same reason. No problems
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
09-10-2010, 11:16 PM | #5 |
Re: Wheel Spacers
Your studs should be fine mine were 1 inch if you have a problem you can cut them down
70 SWB STEPSIDE 70 BLAZER 09 challenger |
09-11-2010, 12:49 AM | #6 |
Re: Wheel Spacers
So your spacer was 1 inch and it fit fine? That's good news. I'll go ahead and get the spacers then. Thanks!
09-11-2010, 06:34 AM | #7 |
Re: Wheel Spacers
Yeah a 1 inch spacer was flush with my studs
09-11-2010, 01:50 PM | #8 |
Re: Wheel Spacers
The front end track was widened on 71's and 72's because of the disc brakes.
