Where did you buy your blazer tank??
Hey guys,
I'm looking to pick up the blazer tank kit for under the bed. Just wondering who to get it from. I'd like to know where you got it from, what exactly came with it, and how easy it was to install. Thanks Eric
Eric 70 CST10 long bed in pieces also factory air and cruise(the project) 18 Silverado crew cab 5.3 4x4 My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166 |
Re: Where did you buy your blazer tank??
Here is one of several threads on this subject. This one has some of the info your looking for and some other good advice. http://67-72chevytrucks.com/vboard/s...d.php?t=420788
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
thanks. reading that thread there is a post that talks about a camaro tank instead of the blazer tank. anyone done this? I'd like to go that route and put the filler behind a flip down license plate. would it still work with a 2/4 drop?
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
In order for the filler to work behind the licence plate, the tank will have to be below the frame. With lowering the truck that will certainly limmit the size of the tank and fuel capacity. Blazer tanks only set partialy under the frame rails and give you a 21 gallon capacity. You can't use a behind the licence plate filler with one of those though, because the neck is too high and gas won't flow up hill. Just a couple of things to consider....
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#5 | |
#6 | |
Champagne Taste on Beer Budget
![]() Quote:
What year model would one look for for this swap? As having the filler neck right behind the license plate would solve a LOT of problems doing this swap!
Coming Soon: Project 1970 Country Truck |
Im not sure I havent found any info on the camaro swap. Im hoping someone can shed some light on it. maybe its not possible??
Its on here somewhere ill look for the post with pictures. The 99-02 camaro/firebird tank is what your looking for. It fits but if i remember correctly you have to move the brace forward. This is imo the best bet for an efi swap. Im looking for one to do the swap then im starting a build post. heres the link http://67-72chevytrucks.com/vboard/s...d.php?t=375410 Last edited by bandit01ws6; 09-11-2010 at 03:31 PM. Reason: add link |
ive been pricing the blazer tanks and they all seem to be about $200. So does it really matter where I get it from or is one better than the other?
I am a Referee of life.
$200.00 sounds like it's for tank only.You may want to check and find out.You want the whole kit so you have the straps and such also.If you're doing a LWB then you might look at fuel lines for a Burb.They should come real close to fitting,though I've never done one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#11 | ||
I've got one of the plastic blazer tanks. I think next time I will go with the steel, or have one custom made out of stainless or aluminum.
The plastic one just seems cheap and flimsy to me.
"Negative people always seem to have a problem for every solution" |
#13 |
Where did you buy yours at?
#14 |
im thinking of getting it from the truck and car shop. leaning towards the steel tank i think.
#15 |
![]() Join Date: Oct 2001
I had a plastic tank also but changed my mind and bought a steel tank from
Truck and Car Shop! I had OE straps and nos sending unit so all I needed was a steel tank. Call Truck Shop and they brought it to the Foodlion AutoFair in Charlotte back in April for $125.00 I thought it was a heck of a deal but I also buy alot of parts from them over the years! Best of luck........
Things happen for a reason! |
#16 |
I like the poly tanks for this conversion and we sell both. Reason is, ease of instalation and they will hold up for many years longer than it's steel counterpart. They are manufactured with cross linked polyethylene that is about 1/4" to 3/8" thick. Coming from a plastics background let me tell you that is some tough stuff. Nothing at all flimsy about them. They also are made in America and are DOT certified. They will withstand a greater impact than the steel tank and bounce back without hardly a mark at the impact point. The steel tanks will both dent and corrode as whitnessed in the original steel tanks in just about all of the vehicles out there. Has anyone seen what the ethinal gas blends do to the tanks, carbereters and fuel lines. Polyethylene is imperviouse to that. Just some more things to think about.
#17 |
I have been looking into the camaro tank conversion. Here is some info I got from Bad70sbchevy. He did it and I think it looks great. I ordered my tank from a company called Tamraz out of IL. They have Canadain tanks. Cost me 194 for the tank, sending unit(compatible with our fuel gauge) straps and an anti squeak kit. Havent recieved it yet but should any day.
Here is the info with links. Hey, sorry about the wait. I don't think they offer a camaro tank conversion, at least not that I know of. When I did mine it was all a custom job. I went down to NPD and got a 1969 camaro gas tank, fuel cap, the flip down license plate holder or the same year and fuel sender (I believe its the one for the 350 with the 3/8" fuel line). The great thing about this it is 100% compatible with the fuel guage on our trucks. I also got some square tubing and mounted it on the frame rails where I believe the spare tire use to be mounted. I used some 1x2 but it could be different in your case depending on your bumber. I also used 1/8 x 1" metal straps to mount it (i just bent it to the shape of the tank). Also I would suggest using tar paper between the tank and the straps to keep it from squeaking. Best advice if you were to do this is be patient and take your time to do it right. Ive had mine for three months and love it and i would definitely do it again and it does not take long at all to fill unlike the blazer tank. I did mine based off of this post http://67-72chevytrucks.com/vboard/s...d.php?t=243181 and here are some pics of mine on this thread http://67-72chevytrucks.com/vboard/s...78#post4111478 hope this helps and if you have any questions feel free to ask. Good luck with whatever you do.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#18 |
#19 |
Well I just orderd my tank the other day from the truck and car shop. went with steel just in case i have to modify it at all. I just want to say thanks to everyone for their input.
