Old 09-11-2010, 02:23 PM   #1
HarrisonTX
'69 C20 Front Drum to Disc help
From what I've been reading, your 1/2 guys have it pretty easy when it comes to swapping from drums to discs up front.
Are there any easy options for a drum to disc swap on a 1969 3/4 "Custom/Camper"?
'69 custom/camper
'74 260z 302 chevy/tko500 swap in progrss
'79 Malibu 355 all forged 4 speed car.
'86 k5 blazer
'06 Duramax
HarrisonTX is offline   Reply With Quote
Old 09-11-2010, 03:37 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: '69 C20 Front Drum to Disc help
Easiest would be to get stuff off of a '71-'72 C-20. Spindles, rotors, calipers, drag link, inner and outer tierods, ball joints as well as master cylinder and prop valve. Still trying to figure out brake hoses/lines on this swap. I think I remember hearing '73 C-20 brake hoses might work with the '69 hardlines. There are some members that have done this swap, maybe they'll chime in.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-11-2010, 04:10 PM   #3
HarrisonTX
Awesome. Didnt expect it to be that simple. I've looked into it before, and was discouraged.
Seems like everything is a bolt on?
You can always get the brake lines made.
'69 custom/camper
'86 k5 blazer
'06 Duramax
Old 09-11-2010, 04:28 PM   #4
Sinister
Between Trucks...
Sinister's Avatar
Everything's bolt in from what I've been told. I have most of the parts to do it, but I just recently rebuilt everything on my drum brakes, so this project is going to have to wait.
Beat it to fit,
Old 09-11-2010, 04:29 PM   #5
tasian
tasian's Avatar
You can also use the 73-87 disc setups like lots of the 1/2 ton guys do just get it from a 3/4 ton if you look around there is lots of info on it all pretty simple unbolting and bolting
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 09-11-2010, 05:19 PM   #6
Mike C
Mike C's Avatar
Not sure exactly what my components were from, but I bought a 70 3/4 ton that already had a disc swap done and swapped it onto my 70 GMC. I bought new steel lines and ran them from the master cylinder. I used the drum booster with a new disc master. I cut the tabs that hold the rubber lines where the steel ones attach and re-welded them to the crossmember. Best mod ever!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 09-12-2010, 12:31 AM   #7
SCOTI
SCOTI's Avatar
Use 73-87 3/4 ton stuff. It will swap over to your existing a-arms using the 73-87 BJ's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-12-2010, 02:29 PM   #8
HarrisonTX
Seems like the simplest idea so far.
So, from the Donor truck, I would need: Calipers, discs and spindles?
'69 custom/camper
'86 k5 blazer
'06 Duramax
Old 09-12-2010, 07:09 PM   #9
treveiger
treveiger's Avatar
The guy that did mine just swaped out the whole crossmember and everything from a earlys 70s truck.
treveiger is offline   Reply With Quote
Old 09-12-2010, 10:32 PM   #10
SCOTI
SCOTI's Avatar
Get everything between the spindle steering arms as well. Use the 73-up tie-rods & draglink for simplicity.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-03-2010, 12:25 AM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Here is the thread I was looking for.
Question:
is it better to just swap crossmember and all?
66 C20 Service Truck:
