1/2 ton vs 3/4 ton frames (86/87 build project)
From everything I have read the 1/2 ton and 3/4 ton frames were the same but they are not. My 1/2 ton 86 frame web width is narrower in the rear section in two spots than the 87 3/4 ton. I was thinking of using the 1/2 ton frame as the cab I am using is sitting on it but as I am springing it for a 3/4 ton I guess I am now using the 87 3/4 ton frame. The difference may not be that big of a deal but I might as well just go with the heavier frame as the work isn't really that much more.
Happy to be here
![]() Join Date: Mar 2000
Re: 1/2 ton vs 3/4 ton frames
Sounds like a solid plan. Post pics of your progress.
Re: 1/2 ton vs 3/4 ton frames (86/87 build project)
Here are a couple photos of the differences in the rear section of the 86 1/2 ton and 87 3/4 ton frames (the 3/4 ton does not have the notches).
I lifted the 87 cab off the frame today and also removed the 86 bed. Hear is a photo of my set-up. I made a spreader beam for my backhoe which slides over my round bale forks. It is 8' long so it does not squeeze the cab or bed. It worked great.
Cool setup... now all i need is a backhoe..
1987 GMC Wrangler - 305TBI/TH400/Duals 1968 Camaro - Resto 2010 Ranger ![]() I only drive truck 6 months a year... Dam Canadian winters.
A Backhoe is a handy tool to have.
Now I have to finish stripping the 87 frame so I can sandblast and paint it. |
