Old 09-11-2010, 11:31 PM   #1
tripton
ive got a starter question
i have a 72 cheyenne 4x4,the motor is a 70 i believe. my starter solenoid went out,not thinking i went and got a new starter instead of just a solenoid.the starter has three bolts, two on the face and one that comes in from behind through the bell housing.simple enough...well the starter i got from napa seemed to be identical till i went to put it in.one of the bolt holes was about 1/4 inch off. i drilled it out , but once installed i gave the key a turn, grind! i took the spacer out,no luck. my question is do they make different starters for auto and manual trans? the guy at napa said no.not sure if i believe him though.my core is already gone,too.how and where do i find the starter i need?
tripton is offline   Reply With Quote
Old 09-12-2010, 08:59 AM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: ive got a starter question
There is a huge difference between manual and auto starters. Manuals bolt to the bellhouse and autos bolt to the block....Dont even look the same.
Curious, but you shouldnt have had to drill anything. Need some pics.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 09-12-2010, 12:44 PM   #3
rsavage
rsavage's Avatar
I have found that the reman 3 bolt manual starters sold at NAPA have new nose cones on them that are too thick. They hit the inside of the cast bellhousing which prevents the starter from seating correctly. If you still have your old starter compare them side by side paying attention to the noses. The reman nose is thicker.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
