Old 09-12-2010, 12:24 AM   #1
AusTx68
AusTx68's Avatar
Blocking unused firewall holes?
Hindsight is 20/20..when I had my cab painted I should have blocked all the dang holes in the firewall. Now I'm trying to figure out what's the best way to cover them up without looking crappy when I pop the hood. Perhaps stoppers or solid grommets? I've looked and can't find any.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 09-12-2010, 08:13 AM   #2
bigsnookmaster
bigsnookmaster's Avatar
Re: Blocking unused firewall holes?
I ran into the same problem with some also. I put rivnuts in the 3/8ths floor insulation holes, then put 1/4x20 stainless screws in them. I still have a few others that will have to be addressed at a later date. Good luck, and be creative.
bigsnookmaster is offline   Reply With Quote
Old 09-12-2010, 11:14 AM   #3
Arizona oldguy
Arizona oldguy's Avatar
Wow what a timely question. My cab is on the ground and I am getting it ready for paint, looks like you patched the heater/AC holes that is what I was planning on, what other holes are you looking to patch. The emergency brake cable hole, throttle cable hole, wiring harness square hole? maybe I am missing something are you planning on using different style throttle etc? Appreciate any ideas you could give me.
Arizona oldguy is offline   Reply With Quote
Old 09-12-2010, 11:26 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Smooth the head on a carriage bolt and paint to match. Adding anything thats another color will draw attention to it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-12-2010, 11:27 AM   #5
Street Lethal '72
Street Lethal '72's Avatar
I ran into a site the other day that had a universal firewall grommet and plug set, being sold for the C10.. that looked like it had everything, cheap.. but now I can't find it.
I guess you could start measuring holes and search by size:
http://www.google.com/products?q=hole+plugs&hl=en&aq=0
Street Lethal '72 is offline   Reply With Quote
Old 09-12-2010, 07:12 PM   #6
guyryan100
guyryan100's Avatar
the other common hole to plug (that I forgot to do) was the clutch pedal hole when converting to automatic. But it's a nice breeze on the feet.
guyryan100 is offline   Reply With Quote
Old 09-12-2010, 08:33 PM   #7
AusTx68
AusTx68's Avatar
If I had been thinking I would have sealed up the entire firewall, fusebox included. I then would have built a custom fuse panel under the dash and hid all the wiring. Oh well, a project for next year
Hey thanks for the link. Lots of good options.
