09-12-2010, 12:45 PM | #1 |
70 w/ 84 brake booster and master cylinder
can anyone tell me how i can make an booster and master cylinder work from a 84 silverado?? can i just knock the studs out and bolt it to the cab or????please help
09-26-2010, 08:35 PM | #2 |
Re: 70 w/ 84 brake booster and master cylinder
someone here has had to install a 80's booster on a 67-72 C10 truck. show some pics and share some knowledge. Brandon
09-27-2010, 12:47 PM | #3 |
Here's what I did. I went to the salvage yard and picked up a booster /mc from a 90 something Suburban type vehicle(one with a plastic reservoir),might have been an extended cab pickup-I don't remember now.At the time my truck had a 3 speed column shift. I knocked out the old studs that the factory manual brake m/c was bolted to. I had to open up the center hole that the push rod goes thru to move it up a little,and the bolt pattern on the late model booster was different so I had to redrill the 2 bottom holes.Then I bolted the booster flush to the firewall. I had to cut the rod going to the pedal and weld my original clevice to it to attach it to my brake pedal,but it worked perfect.Then,when I swapped out the transmission to an automatic,I discovered the bigger booster interfered with the auto trans shift linkage,so I made another trip to the salvage yard and picked up a small diameter booster from an S10 Blazer. I have excellent brakes,one of the best mods I've made to my truck-next to power steering
09-27-2010, 02:27 PM | #4 |
Not sure if this will help, but here is what I did.
http://www.67-72chevytrucks.com/vboa...d.php?t=379146 |
