Old 09-12-2010, 09:00 PM   #1
ozman3803
static drop pics and help please
Having trouble finding pics and specs. So links, pics or any help would be appreciated. Ok, here is my ideal set up. 70 c10 with the 73+ front crossmember. 5/7 static drop with 3" belltech spindles and 2" drop spring. Rear with c-notch and would be 5" spring with 2" block. I'd like 17/18 coy's staggered. Any preference on backspacing and tire size? Would like the wheels to tuck wheel wells or at least come close. Am i going to run into turning or alignment issue? How is handling and ride quality? Thanks for the help everyone.
ozman3803 is offline   Reply With Quote
Old 09-13-2010, 06:06 PM   #2
ozman3803
Re: static drop pics and help please
Bump for some help
Old 09-15-2010, 03:58 PM   #3
ozman3803
<<bump>>
Old 09-15-2010, 04:17 PM   #4
tubbedII
needs more $$$
tubbedII's Avatar
I've only read a lot of posts about this...so this is just from what I've heard:
-You don't need the 73+ x-mbr...just swap the bjs in your control arms for 73+ bjs and get the 3" drop spindles/springs for the front end 5" drop.
-You got it right for the 7" drop in the rear.
-Tire size is a matter of your preference...pick what you like best
-Backspacing could be different on each ride, so it's best to measure to see what fits (after you drop it)
-Turning shouldn't be a problem with 17/18's unless you get a really big tires
-Get an alignment when done (with new tie rods most will say)
-I have a 4/6 on my blazer...it rides decent
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-15-2010, 05:37 PM   #5
hotrodhomi
hotrodhomi's Avatar
if you are going that low, why not bag it? it will help when you need more clearance.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 10-09-2010, 10:01 PM   #6
ozman3803
Well it's been awhile and still no pics. Thanks for the input everyone that has post. I really considered baggin it but for now I want to do a static drop primarly due to budget and I just want to drive it. Don't have an extra 2000 laying around for my ideal bag set up. Well I ended up getting the 77 crossmember disassembled and hopefully send the frame in for sandblasting soon! Thanks again, pics would be great.
Old 10-09-2010, 11:31 PM   #7
TonyC66
TonyC66's Avatar
Not sure if this helps:
7in drop in the rear with a c-notch, 5 in coil and 2 in block
3 1/2 in the front, 2 1/2 spindle and 1 in coil.
The rear tucks a bit and the front fender meets the tire in the front. I would like the front an inch lower, but this way I am able to drive it with no issues. It is my daily driver, so i have to keep it this way.
TonyC66 is offline   Reply With Quote
Old 10-10-2010, 01:31 AM   #8
stefan
New Member
that is one nice truck.
stefan is offline   Reply With Quote
Old 10-10-2010, 05:55 PM   #9
ozman3803
Nice ride tony and thanks for the picture. Nice stance, would there be rubbing issues you think with an additional inch in front?
Old 10-10-2010, 08:29 PM   #10
chuckmc8
It's alsways something.....
chuckmc8's Avatar
Mine has 5" drop springs in the rear, drop spindles and 1 coil off the front springs, no C notch and no rubbing issues, drives and rides good
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie
1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts
1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e
chuckmc8 is offline   Reply With Quote
Old 10-10-2010, 08:50 PM   #11
TonyC66
TonyC66's Avatar
Thanks for the compliments,
ozman,
I think you should be ok going down another inch with 18s, as for me it might rub since i have 20s up front. I would love to try it, but don't want to risk it since its my driver.
Old 10-10-2010, 10:04 PM   #12
ozman3803
Thumbs up Re: static drop pics and help please
Nice lookin stance to chuck. You running 15 in wheels on that. Awesome color choice to man.
Hey tony, I might have to consider 20's (coys c5's?) after seeing your ride. What backspace did you go with on front and rear. Also tire specs would be great to. Appreciate the help that's coming through guys!
Old 10-10-2010, 10:10 PM   #13
TonyC66
TonyC66's Avatar
They are actually American Racing TTII's. I went with 4 3/4 bs all around, that might work for you in the front depending on your brake setup, but wouldn't in the rear since your year truck has a longer rear end. I would reccommend you measure for your bs before you order wheels. I must have measured 3 times before i ordered mine. Tire sizes are 245/40 and 295/40.
Old 10-10-2010, 10:52 PM   #14
denny5625
denny5625's Avatar
I have 15 x 10's on the rear with 5" BS and 295/50-15 tires and the tuck pretty well. If you go with a narrower tire you should have plenty of room.
66 el Camino
70 1/2 RS Z-28
71 C10 2wd
72 2 wd Blazer
(2) 72 4 x 4 Blazers
88 24' Mirage 70 mph+
08 Harley Night Train
08 Silverado 4d 4 x 4
denny5625 is offline   Reply With Quote
Old 10-10-2010, 11:12 PM   #15
lolife99
67-72 parts collector,…
lolife99's Avatar
5.5"/7.5" drop.
Keith
Convert to disc brakes.
Old 10-10-2010, 11:14 PM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
4.5/6" (not quite a 5/7) running 20x8's and 20x10's:
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-23-2019, 09:18 AM   #17
bucktruck68
5.5"/7.5" drop.
Any issues with the drive shaft? Did you have to adjust the rear axle angle?
bucktruck68 is offline   Reply With Quote
Old 09-23-2019, 11:36 AM   #18
lolife99
lolife99's Avatar
No.
The truck now belongs to member "n2billet" and has a 2" lowering block. for a 5.5"/8" drop.
Keith
Old 09-23-2019, 12:56 PM   #19
bucktruck68
No.
Old 09-23-2019, 07:33 PM   #20
Andy4639
Old member
Andy4639's Avatar
My 71 static drop with 2" springs up front 4" springs out back. I have air lift air bags in all 4 of them for a better ride.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-24-2019, 11:34 AM   #21
1972 C10
1972 C10's Avatar
I put in Air-Lift bags in rear many years ago. Now 1 needs replacing and Air-Lift is no help. Do you happen to have part number for rear bags? I probably need to mention, this is stock height, bags were to support load.
THANX
64 Chevy Suburban/Carryall 4x4
72 C10 Highlander LWB
34 Chevy 5 wdo Street Rod
64 Corvette Roadster w/AC
78 TransAm WS6
78 GMC Jimmy 2WD Slammed SOLD!
1972 C10 is offline   Reply With Quote
Old 09-24-2019, 07:26 PM   #22
Andy4639
Old member
Andy4639's Avatar
Talking Re: static drop pics and help please
THANX
Read my signature it's in it.
Old 09-24-2019, 08:12 PM   #23
1972 C10
1972 C10's Avatar
THANX, I'll check it out w/only one number I thought that was for a kit, front & Rear.
78 TransAm WS6
Old 09-24-2019, 09:35 PM   #24
Andy4639
Old member
Andy4639's Avatar
No it's just for the back. I added the fronts after this.
Here is a link for more.
https://www.sdtrucksprings.com/index...&keyword=81560
Old 09-24-2019, 10:11 PM   #25
1972 C10
1972 C10's Avatar
Thanks again, info has gotten me closer but I need to measure to be sure. Airlift wanted exact measurements from me. I was afraid w/o removing bad bag & spring, measuring used bag w/grooves from spring, I would end up w/the wrong bag. This leads me to measurements of available bags to find the right ones. I thought w/the popularity of these trucks and air lifts involvement in converting to air suspensions, that they might have revived their old applications list. I bought mine over 20 years ago by application. I will admit to being old and getting somewhat lazier.lol
78 TransAm WS6
