1987 Chevy R10 Restore
I got this truck after trading my 1990 351w mustang GT. I have started what has become a lot of work. It came with 305 tbi and th400 trans. I will be putting in a 350 tbi. I will list everything i do to it as i can. I need all the motivation i can get.
87 Chevy R10 LB 02 Nissan Sentra GXE Last edited by texasbigbear_wink; 10-18-2010 at 09:03 PM. |
Re: 1987 Chevy R10 Restore
This is what i am planing on doing to the truck.
Edelbrock 3704 - Edelbrock Performer T.B.I. Intake Hedman Hedder 69890 - Hedmans Elite Hedder 2 1/2inch strait duals with flows dumped 350 tbi injectors Electric cooling fans 105 amp ALT Rims/tires Level/lower it Spray in bed liner Get rid of that rear bumper Paint Tint windows Ect.
87 Chevy R10 LB 02 Nissan Sentra GXE Last edited by texasbigbear_wink; 10-20-2010 at 11:00 PM. |
![]() Join Date: Dec 2008
Sweet
Thanks I am looking forward to getting this show on the road.
87 Chevy R10 LB 02 Nissan Sentra GXE Last edited by texasbigbear_wink; 09-12-2010 at 11:27 PM. |
the pollock
when you go to purchase the alternator check against the other GM alternators.
mines from a 454 power everything truck and was 60 bucks less then the "120 amp performance" model specifically for my truck... it's retared but that's the way it's coded in the computers at the stores... good luck!
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
The mustang needed a lot of work and would have required more money in the long run. Don't get me rong I loved the mustang but I needed a truck and that is a good reason to spend some money on it without getting to much crap from the wife.
87 Chevy R10 LB 02 Nissan Sentra GXE |
Nice work so far. I think it was a good trade.
86 Suburban 2WD = rolled it and totaled it ![]() 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. ![]() 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
Welcome, Texasbigbear -
Take a look at my build thread, if you are interested (my Introduction thread linked below). Start to finish was about 5 months, and I did it all in my driveway (my truck has never been in my garage). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
NICE!! I love your truck I hope to do body work to mine but I am more on getting everything running perfect first I have about $1,800 just in all new shocks,brakes,rotors,drums,wheel bearings,sway bar bushings,A frame bushings,inner&outer ti rods,pitment arm, idler arm, lower and upper ball joints, 105 amp alt, all new sensors, water pump, power steering pump, radiator, all hoses, plugs, wires, rotor, cap, belts, battery, battery cables, Man list goes on I am just waiting on the 350 and some more money to order the rest of the stuff I need then I will get moving on it.
I will be working on painting the engine bay and chassis this weekend not sure how much I will get dun but I will do my best to post the progress as i can.
87 Chevy R10 LB 02 Nissan Sentra GXE Last edited by texasbigbear_wink; 09-13-2010 at 09:33 PM. |
I got some painting dun I will do some more when i get some more paint.
#13 |
Lookin' good! I'm going to keep an eye on this one. I could always use more inspiration for my 87' R10 build!
#14 |
very nice man.
deer hunting, fish catching, 4x4ing country boy |
#15 |
Thanks men I will put some more pic's up this evening. I hope to finish painting all the front this weekend if the weather is nice. Thanks for the support.
87 Chevy R10 LB 02 Nissan Sentra GXE Last edited by texasbigbear_wink; 10-19-2010 at 10:29 PM. |
#16 |
been here longer than Liz
'87s rock, nice choice. You'll also want to pick up a new chip since you're going to a 350. The 305 chip will work, but a proper chip will work better.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
#17 |
looking good. imo 87's are the best
#18 |
Thanks... I have purchased a prom chip from jet. I am really looking forward to getting this truck on the road but have ban limited on my spending but please bare with me as I don't plan on having it runing till about march but I hope it will be a lot sooner.
![]() Posted via Mobile Device
#19 |
TH400 trans and some more pic's......
#20 |
TH400 after some TLC......
#21 |
Nice restoration there!
I'm doing a restoration on my '89 silverado and saw you were painting the frame and I need to do some painting to my frame too so did you sand and paint or did you just use spray paint? Just wondering, i'm new to this and learning as it goes |
#23 |
I used a 3000psi press- washer and cleaned it till there was no grease on anything then you can use a good oven cleaner that don't require heat and let it set for a few days it works well then clean it again. The frame is painted with rustOleum rubberized undercoat
This works well cause I found it sticks well to just about anything. The fire wall is low gloss black dupli color engine paint but that is because I had five cans of it setting around. Posted via Mobile Device
#24 |
On the trans I used the pressure washer to get it clean as possible then gave it a soak with oven cleaner and let it set a few days then p washed it again. Repeat if needed.
#25 |
