09-12-2010, 11:12 PM | #1 |
75 chassis to 86 body
Hi all,
I have a 75 3/4 ton 4x4 snow plow truck that the body's falling off. Also have an 86(or so) 1/2 ton 2wd with a fairly solid cab. Thinking of matng the two. Now let me make this clear, it ain't for pretty. The idea is to keep my toes warm and the windows defrosted. Looking today some things I wonder: Master cylinder, what to use? Radiator, will the four-core from the 75 fit the 86 radiator support w/the proper top brackets or what? Will the steering boxes interchange w/a pitman arm change? The one on the plow truck leaks bad. Thanks in advance. I half-a$$ searched if this has been beat to death sorry. |
09-13-2010, 12:09 AM | #2 |
Re: 75 chassis to 86 body
I would use the master cylinder from the 75, it should bolt up to the 86 power brake booster. I have a 4 core radiator out of a 77 in my 86 suburban so your radiator should swap over with the correct brackets. the steering box from the 86 will not work in the 75 the sector shaft turns the wrong way.
1978 Chevy C10, 1986 Chevy K20 'Burb, 1970 Chevelle, 1996 K2500 'Burb, 1977 Chevy K10, 1970 Ford F-250, 72 Ford F100 4x4, 1979 Chevy C30, 1982 Chevy C30, 1996 Chevy Dually 4x4 SAS, 1997 Chevy Tahoe, 1991 Ford F-350 cclb dually 4x4 |
09-13-2010, 06:52 AM | #3 |
also remember that your going to have to cut the tunnel out and put a 4x4 one in, or use a body lift. The tunnel in the 2wd trucks sits lower and will not fit on a 4x4 chassis with out mods.
86 Suburban 2WD = rolled it and totaled it 83 LWB STD Cab 4x4 = went to the scrapper. Was my baby. 84 Suburban 2WD = stripped it/ scrapped it 81 8 foot bed made into a trailer 86 Suburban going to be made into a trailer 91 Suburban 4x4 = that's my baby 00 S10 Xtreme STD Cab 01 S10 ZR2 |
09-13-2010, 12:27 PM | #4 |
Thanks guys.
I'll have to find a cab with a good tunnel, mine's too rusty to cut out. Thought about a body lift before. I oilcan the doors turning into snowpiles. Never decided if the extra height was good or bad for visibility. |
