09-13-2010, 10:49 AM | #1 |
thinair
4x4 driveshafts
1st is a rear from a 1975 3/4 ton 4x4 stick........$30 plus ride
2nd is a front u-bolt strap style. Shaft is good,splines decent,and cv is junk.16" weld to weld.......$20 plus ride 3rd is a front u-bolt strap style. Shaft and cv are good. Splines iffy. About 14 1/4" weld to weld........$30 plus ride 4th is a front u-bolt strap style. Shaft is good. 12" weld to weld...........$10 plus shipping |
09-15-2010, 11:55 AM | #2 |
thinair
Re: 4x4 driveshafts
offers??
09-17-2010, 09:13 AM | #3 |
Re: 4x4 driveshafts
I could probably use the 2nd one (the longest one). I need on for a divorced np205 front, so i would probably have to retube it anyway. When you say that the cv is junk, do you mean it needs u-joints? Or is the housing body just nfg?? Thanks john
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-17-2010, 06:33 PM | #4 |
thinair
Re: 4x4 driveshafts
u-joints are probablly good,the cv is "nfg". it has a hole worn through the middle.
