Old 09-13-2010, 11:27 AM   #1
landarts
landarts
Rusty bolt restoration
Has anyone used this product http://www.eastwood.com/ew-rust-dissolver-gallon.html
Or have a different method of restoring old bolts that have rust on them. I do have a sand blast cabinet, however that is a long drawn out process. Any thoughts would be appreciated.
landarts is offline   Reply With Quote
Old 09-13-2010, 11:35 AM   #2
KEL
72 GMC
KEL's Avatar
Re: Rusty bolt restoration
Just get the grease off of them, and then drop them in a jug of vinegar for a few days. Most of the rust will disappear.
KEL is offline   Reply With Quote
Old 09-13-2010, 11:48 AM   #3
69sixpackbee
I have battled this for years on old stuff I can tell you that once the metal is contaminated it can really make a mess. It is not as simple as removing the iron oxides that you can see you must take into account the chemical process that you are about to start, and this is one that you don't want any part of! Do yourself a favor and use Phosphoric acid because it will remove the oxides also but it will start the right chemical reaction that will leave the phosphate coating that will inhibit rust instead of accelerating it. The Phosphoric acid may take a little longer but it is definitely the better way to go, usually the fastest way out of something just leads right back in!
Read this:
http://www.ehow.com/how_4487861_remo...from-iron.html
69sixpackbee is offline   Reply With Quote
Old 09-13-2010, 11:50 AM   #4
Myself
Round up everything you want clean, then drop it off at the local machine shop. They'll put it in a basket and acid dip it for just a little money.
Myself is offline   Reply With Quote
Old 09-13-2010, 12:22 PM   #5
cdowns
cdowns's Avatar
$2 or so you can buy a gallon of vinegar// soak bolts for a few days or so, rince with water then a solution of baking soda and they're good to go
strain and save vinegar use as salad dressing for unwanted house guests
Old 09-13-2010, 09:54 PM   #6
dfwright
dfwright's Avatar
Check out this thread Bolt Restorations
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 09-14-2010, 10:03 PM   #7
guyryan100
guyryan100's Avatar
Why not just buy new bolts? Not being a smart a$$, am really curious.
guyryan100 is offline   Reply With Quote
Old 09-14-2010, 10:21 PM   #8
Sammy
I am in the same thought process especially the common hardware stuff. Hardware stores sell that stuff by the pound for a couple of bucks or so. And if you not doing suspension stuff, stainless hardware isn't badly priced if you want the shiny sparkling bling.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-15-2010, 11:27 AM   #9
GRX
GRX's Avatar
Read this:
^^^ - this.
Naval Jelly is tried & true.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 09-15-2010, 01:06 PM   #10
vectorit
What?
vectorit's Avatar
In my case, I didn't want to spend the money for new fasteners if all that was needed was some elbow grease to restore them back to the way I wanted.
Plus many times you can not get new bolts that "exactly" match the ones you already have, such as a certain plating, shape, head stamp, length, or ones that have a special washer attached.
I get picky about these details when you can see them, or they are serving a purpose that requires an exact replacement.
Not that I am all about "Concours d'Elegance" show of my truck, it's just that I tend to be a picky SOB with tiny details like this.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-15-2010, 02:12 PM   #11
69sixpackbee
I'm with ya, bro.
Old 09-17-2010, 08:51 PM   #12
292farmer
292farmer's Avatar
i just spit my drink all over my wife from laughing so hard (whose pregnant and pissy) when i read the unwanted guest part,
1972 gmc c25 292/sm465 dana 60 w/5.13s
1973 vw super beetle 1600cc/4spd(baja bug)
1974 chevy c60 351v6/np-540+2 speed eaton rear
2005 chevy cobalt 2.2l
292farmer is offline   Reply With Quote
Old 09-17-2010, 10:44 PM   #13
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Sorry if the link talks about tumblers. That's what we use on our old bolts. Stick some blasting media in a cheap tumbler and turn it on, and in a couple of days and no effort, they come out nice. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 09-18-2010, 01:19 AM   #14
Bad70sbchevy
Bad70sbchevy's Avatar
What about cleaning it up with a wire brush? Worked well for me and you can get one for a cordless drill for dirt cheap.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 09-18-2010, 01:58 AM   #15
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Yup! Wire brush them and oil the clean threads after running
a die down them. If you want the heads to stay looking new...clear
coat them, paint or keep them well oiled.
ETsC10 is offline   Reply With Quote
Old 09-18-2010, 07:53 AM   #16
srea76
srea76's Avatar
I always use vinegar. They come out looking brand new in just a day or 2.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
Old 09-18-2010, 08:35 AM   #17
Thealien
Thealien's Avatar
Thanks for linking this. Its pretty easy to get great results.
Old 09-18-2010, 09:53 PM   #18
DaddyO
DaddyO's Avatar
I used this:
http://evaporust.com/
Worked really well for me.
DaddyO is offline   Reply With Quote
Old 09-18-2010, 10:33 PM   #19
LEEVON
LEEVON's Avatar
I think I'm going to refinish a couple of bolt buckets that are taking up space. After a little research, it looks like they have good reviews for a cheap vibratory tumbler.
http://www.midwayusa.com/viewProduct...tNumber=158440
Then the caswell plating black oxide kit from the other thread:
http://www.caswellplating.com/kits/black.htm
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 09-22-2010, 05:16 PM   #20
Thealien
Thealien's Avatar
Just want to say that I have not had good luck using a tumbler. I have one and it didn't seem to work (I was using the same media I tumble shell casings in). I have had the best luck with a sand blast cabinet. I would be interested to know how a tumbler would work with a more agressive media.
