Old 02-25-2003, 12:37 PM   #1
Joe E.
Question Quadrajet is leaking down overnight??
My smallblock has a rebuilt Quadrajet that takes
alot of cranking and pumping to get it started
after it sits overnight.
I have an HP Book on Quadrajets that leads me to
believe the plugs in my float bowl are leaking. They
mention using epoxy to seal up the plugs. If anyone
has done this what type of epoxy should I use?
Do you think these plugs are my problem? Or could
it be something else?
Thanks!
Joe E. is offline   Reply With Quote
Old 02-25-2003, 04:08 PM   #2
Mike C
Mike C's Avatar
Most likely that is your problem. Any two part epoxy should work fine. Truck will have to be down a day or two. Other option, buy a JET stage II Q-jet with electric choke. They run great look nice and solve lots of drivability issues that 30+ year old carbs exhibit. That's why I did on both of my trucks, and consider it $350 WELL spent.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-25-2003, 04:40 PM   #3
Blazer1970
Blazer1970's Avatar
I have used the 5 minute JB Weld. I have little patience. It worked good. Your accelerator pump might also be the culprit. Have you looked down the carb and actuated the throttle to see if it is spraying gas when you do?
Blazer1970 is offline   Reply With Quote
Old 02-25-2003, 07:01 PM   #4
Piston
Piston's Avatar
One of Quad's biggest problems.... Fuel well soft plugs. They do leak.. it can completly empty the float bowl causing long crank times and hard starts.
Mike C nailed it, us a 2 part epoxy and completly coat the plugs and lower fuel well area close to the plugs. This repair will last you a good long while.
Piston is offline   Reply With Quote
Old 02-25-2003, 07:12 PM   #5
Joe E.
Thumbs up
Thanks guys!
I'll find some 2 part and attempt to seal her up.
