Old 02-25-2003, 01:05 PM   #1
cheyguy
cheyguy's Avatar
Engine Problem Help!! '80
I've got a problem and I'm not sure what to check next! My '80 4x4 has a 350 w/auto trans that starts fine, idles fine, runs fine till it shifts into 3rd, then the engine really boggs down. I took it to my trusted mechanic who said it was the tranny. Well $2000 later and a rebuilt tranny it still no better. But now when I accelerate above 40 mph or go up hill the engine sputters and revs (like a clogged fuel filter). I've changed the fuel filter, checked all the plugs and wires. I'm thinking I need to rebuild the carb but I'm not sure thats my problem. Any ideas are appreciated. Thanks, Mike
'71 Cheyenne Super
'80 Custom Deluxe
'75 Blazer
cheyguy is offline   Reply With Quote
Old 02-25-2003, 01:09 PM   #2
72CustomCamper
You mentioned it "sputters and revs". If it is revving up under load then something is definitely slipping somewhere...could still be your transmission.
Give us more info!
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454
'93 K2500 Suburban, Old 454 (157K)
72CustomCamper is offline   Reply With Quote
Old 02-25-2003, 02:09 PM   #3
lpaine
lpaine's Avatar
Could possibly be a bad fuel pump(check pressure) or ignition timing out/not advancing probably something simple. Too bad about replacing your trans. I would suggest you consider getting another "mechanic" that knows how to troubleshoot problems, I think you would always check the simple things first.
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 02-25-2003, 03:03 PM   #4
JimKshortstep4x4
Talking
If your fuel pump is good, check your in tank pick up filter. From what you are describing, it sounds like it is short on fuel.
Jim
Old 02-25-2003, 04:03 PM   #5
wnc mountain
More hobbies than money!
wnc mountain's Avatar
had an '80 a while back, sounded about the same. it was the fuel pump.
'70 cst10/swb 350, 3 on the tree, factory buckets.
'70 GMC lwb 350/350 ps,pb
'72 c-10 lwb 350/350 a/c, ps, pb
'72 Blazer project
wnc mountain is offline   Reply With Quote
