whats the best engine paint
looking for a good paint that will hold up on my engine and not flake off or melt after a year.and do i need to put primer on it first . thanks
Re: whats the best engine paint
I've pretty good luck with VHT...
i second the VHT^^
1963 C10 Shortbed: project, shaved, slammed 1965 C10 Longbed: 355, 4pd new process, Daily Driver 1991 F150: 300 inline, 3in lift 33s, Stacks. RIP 1992 Dodge 250: 98.5 12valve, 500hp POD injectors, rolls coal... 1986 Chevy 4x4 Shortbed: 4in lift, 33s, daily 1995 2500: 6.5 TD, straight piped, the tow mule |
i have heard good things about the por 15 engine paint.but i have not tried it myself.let us know what you use.
do i need to primer the engine first or just paint it if i use the VHT
Redneck Hillbilly
If I remember correctly the VHT cans actually recommend that you don't primer it first. If there is someone who is on has a can nearby can verify, I don't have any cans at the moment.
Senior Enthusiast
Here's a link that describes recommended practice for application of VHT. No suggestion to use primer, just make sure everything it clean. Engine enamel is the second section:
http://www.caswellplating.com/vht/vht_high.htm |
![]() Join Date: Oct 2009
i've used vht primarily - and the best results I have gotten were after hot tanking when I had machine work done - then PRE prep (Eastwood metal prep) and then spraying multiple thin coats with no primer. seemed to work pretty well on the block and heads and pan, etc. As for other painted (but not block color) things in/on the engine - I really like the Eastwood selection fo stuff (aluma blase, spray gray, etc etc) - they look pretty correct and hold up better than bare metal.
Moderator
![]() Join Date: May 2007
POR is fantastic. I have used it on numerous engines. I used it last on my 72 daily driver. 4 years later, still looks brand new.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
thanks guys for the options
I havent found VHT in gold, do they make that?
This statement was made possible by a grant from this station and continued support from viewers like you. Flickr |
Boat, spray or rattlecans?
you didn't say what level of disassembly you're at or willing to go to. The best of course is to lift the engine out and remove things down to a long block, degrease well, use some CLR on any bare iron, then spray with automotive paints: a wash primer works well on bare cast and steel and a simple single stage color, mixed to your choice. If you have air and a spray gun you can handle this, even at novice level. The local paint supplier can set you up, and your body/collision center can too. Otherwise, your talking rattle cans. Posted via Mobile Device
292 + TKO500 |
#13 |
#14 |
Senior Enthusiast
If you're set up with spray equipment, I've also read that any catalyzed acrylic enamel or urethane can provide show quality results, although for many this may be overkill.
#15 |
6>8 Plugless........
![]() Join Date: Sep 2007
I have had very good luck with VHT rattle can. Their high temp paint is the only brand rattle can I have had any luck keeping on high heat diesel exhaust manifolds. Even the POR high heat paint doesn't work as well as the VHT high heat paint.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#16 |
painted in `03, looks the same today, just two coats of industrial stainless enamel, no primer, block had been scrubbed with redstar grease remover and hot water before painting, as long as all reminants of grease and oil are gone, the paint will stay.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
